How to: 2 Door Rear Seat Removal
Beach_Bum
St. Augustine, FL
Tore the buckles apart and started making the base
it will be 12” clearance under
more photos on my build thread
Ford Bronco How to: 2 Door Rear Seat Removal E02EA58A-7CA4-4922-B8D6-D5482E62BD51
What are the clips for? No mention on your Build Thread.
mcinfantry
Lee
Louisiana
Badlands 2 door
Your last two photos of plastic parts in your hand.
That’s the electrical connection in both seatbelts
I bought a left and right and took them apart to use instead of removing the buckles from the frame
stonerdoom
chicago
2004 Ford Explorer Sport Trac
Reports here of poor quality for the high price
Sorry, had missed the alert earlier as I had been posting a lot. Thank you for the response. But to be clear, you do not own the platform? I am very open to being talked out if it because of the price so I am all about intel on this piece.
mark1031
Elkton, Oregon
2022 Bronco, 1966 VW Bus, 1999 Porsche 911
That was my plan as well. Did you get it working?
Arcteryx512
Albany NY
2022 Ford Bronco - 2 door
You need to remove the buckle from the seat and plug it in. There is a perfect pocket made to hide it.
If you remove the belts as I did, you need to install a 2.4ohm resistor into the plug.
Is this 2.4 or 240 ohms. hard to tell if the colors are
Is that 2.4 or 240 ohms. It’s hard to tell if the colors are red, yellow, gold, gold (2.4) or red, yellow, brown, gold (240)
telenerd
Laramie
Subaru
Great tips. I got my rear seats removed. Any tips on removing the plastic panel so I can remove or tuck in the seat belts? Didn’t want to go in it without a plan!
Ford Bronco How to: 2 Door Rear Seat Removal IMG_4981
Ford Bronco How to: 2 Door Rear Seat Removal IMG_4982
