Install Notes on Baja Designs Triple Fog Light Kit w/KR Off-Road Brackets from 4x4TruckLEDs
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
leby065
Chicago
Infiniti FX35
Professional Tip: You should space the lights out more. You've got room on that bracket to slide that S2 outwards more. Just my OCD :) Unless you have the ORIGINAL bracket, that didn't let you slide it out that far?
@4x4TruckLEDs.com I think I have the original bracket - bought in November. Does the new bracket allow for any other changes other than better spacing? Finally got my Bronco and am going to install once we get warm weather and I can buy a TP40 bit.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Well we extended the "new" bracket out more so that the lights were not so on top of each other and you could utilize the entire space. I'd need to see a picture of which bracket you have
leby065
Chicago
Infiniti FX35
Ah, yea - I’m guessing I’m on the original ones. Haven’t put them on yet.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Yes looks like the original brackets
FairPlayInc
Billy
New York
2022 Bronco Wildtrak
Those that have completed the install, which row did you mount your lights to? The one closest to the 45 degree bend, the middle or the one further at to the back?
Bonnie6G
Kyle
Denver
Badlands LuxSquatch
I’m about to install this kit. Question- If You use the shorter stock mounting arms for the lights, why do you have to flip the faceplates?
vegetarianbarbarian
vegetarianbarbarian
Ara
Novato, CA
2021 Ford Bronco 4dr
Only if you want the test on the faceplates pointing in the right direction. Otherwise it's irrelevant.
Bonnie6G
Kyle
Denver
Badlands LuxSquatch
Lol! I’m OCD, but not that OCD. Thanks, I wasn’t sure if it had to do with the angle of the lenses / reflectors or something.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
So that the bezel writing is not upside down.
Also, if you have Driving/Combo most want the spot portion on the top with the wide cornering on bottom. This way you can aim the lights so that the spot is in line or JUST above your headlights and the lows will be a bit below it for best results.
Otherwise you don't REALLY Have to, it's just for that OCD.
