Keeping 4 door rear shell removed
Yolobaggins
Toyota Rav4
So I was looking at pictures and am trying to envision keeping the 2 top pieces on but removing the rear clam shell, going with the safari type look
Would the backseat be covered from rain and the elements? Could you get a cargo cover of some sorts and be able to permanently drive without the rear shell unless of extreme weather?
I think this looks better AND would be easier to change the roof quickly for bad weather/good weather
attworth
Tony
2000 Land Rover D2
I don’t think we will really know until we see how the hard top panels attach to the roof structure. I would guess probably not though.
Philly
Dallas, TX
2022 JL Rubicon
It looks like the middle section (over the rear seats) will just barely come to the edge to cover the rear passengers. This may work for light rain if you are in a pinch, but judging by this photo, it looks like the tapered edge could be a problem.
I have used just the front "freedom panels" on my Jeep hard top to cover the front seats in the past and it will protect you from some rain, but it is far from perfect. You will still get wet if the wind shifts to come in from behind you.
Your best option is probably to wait for the aftermarket to make a soft top option that suits your needs. Jeep has this thing called the BackBone that covers the cargo area and the same company also offers a rear windshield to be used with a safari style soft top. The tops can be found here from Bestop, but I believe it is compatible with other manufacturers. Bestop is just the OEM manufacturer for the Jeep soft tops so it is the most popular for aftermarket as well.
If there is enough demand, someone else will come out with something similar for the Bronco.
Ford Bronco Keeping 4 door rear shell removed 1601334323811
Ford Bronco Keeping 4 door rear shell removed 1601334294447
MaverickMan
Shane
Come on aftermarket!
rgwinn
Rod
Salem, OR
2001 Harley Road King
Ford Bronco Keeping 4 door rear shell removed C40A8370-3C03-4EBE-ABD6-C5EF5A549D09
I could see Bestop making a slanted soft top for the rear like they do for the Wrangler. And maybe a cargo strap
vintage
Summerfield, N.C.
Wrangler JLU Rubicon, 4Runner Trd Pro, Indian Chieftain, Indian Springfield
It might get a little cold and wet in the winter months completely open, depending on where you live. As someone mentioned, there will probably be a bunch of after market option after the first release. Who knows Ford might already have a slanted back option in hard and soft top. Something like pic would be pretty cool, IMO.
Ford Bronco Keeping 4 door rear shell removed 2252293-1-revo
Philly
Dallas, TX
2022 JL Rubicon
I have a slanted back soft top on my Jeep during the summer and I get loads of compliments on it. It really makes a difference on the four door because of the angle of the sport bar over the cargo area. Unfortunately, two doors wont get that dramatic fastback look for the same reason. The sport bar prevents the steep angle.
I am willing to bet Bestop makes a nearly identical soft top for the Bronco.
Fuzion2Bronco
Asher
New England
Base Sasquatch
I saw a Wrangler 4 Door with the same Slanting Roof with the Spare Tire Custom Mounted on it. It was really a cool mod.
Not exactly like picture, but it was a bit higher.
Ford Bronco Keeping 4 door rear shell removed 1601393101911
Headsong
Cool look, but doubt I'd ever use it since it cuts your cargo space so much.
