I change my own oil. I have the 2.3 motor. Once bash plate is removed the drain plug is simple. Getting the filter off is another thing altogether. Front tires must be turned all the way to the right. Ratchet with one long extension, one short extension and one swivel connected to the filter “ cap style” wrench and there you go. Unfortunately Oil drains from the filter as you remove. There is a built in drain chute but actually pulling the filter out through the wheel well is when spills occur. I am curious about the “ replace the oil pan plug”mention. I have not been able to find actual documentation stating it needs to be replaced after a few changes. My metal plug seems rather sturdy.Agree! I took it to the dealer and they put dye in the motor and no signs of it leaking yet. They said to drive it for a week or so and bring it back to see if the dye appears. I think one of two things. Either the tech who changed my oil there was so sloppy that he sprayed oil all over or the plastic drain plug is worn and needs to be replaced. I asked about that and he said it should be replaced every 2-3 oil changes. I only have 12000 miles and changed oil twice now. My guess is they were just sloppy which isn't surprising. We will see.
