Modular Hard Top on Black Diamond?
Gamecock
  • Thread starter
  • Banned
  • #1
Is it verified that there will be no modular hard top availability on Black Diamond? I had just about come to grips with changing from Badlands to Black Diamond, and figuring out how to manually remove the Front Swaybar...but then I saw someone say that you can't get the Black Modular hard top with Black Diamond....that would be tough to swallow. I don't want the gray one, so it would mean buying the truck with a soft top and adding the Hard Top down the line, which would be a pain and expensive I would think. It makes no sense for Ford not to offer that top as an option...that I can figure out.
Fubl
MARYLAND
01 buick lesabre
I was asked about two hard tops when I took the survey and it was for the molded and multipiece for black diamond 2 door
BroncoJay
Iowa
Tacoma
I have the same thoughts about the HT
I’ve been pretty certain I want and probably will order the BD but absolutely hate the grey plastic top, it seems mismatched with the black fender flares and black mirrors.
I was contemplating going up to the BL for the painted HT, but don’t really want to ...
Casual Pork
Cardo
RDU
2022 4D Black Diamond
Here's whats listed on the Ford website. Hope it stays valid for order taking.
https://www.ford.com/suvs/bronco/2021/models/bronco-black-diamond/
Optional
  • Hard Top (4-Door) Molded-in-Color Carbonized Gray
  • Dual Tops - Carbonized Gray Molded in Color + Black Soft Top (4-Door Only)
  • Dual Tops - Modular Hard Top Body Color-Painted + Black Soft Top (4-Door Only)
I like the idea of a soft top to put on in case of rain when traveling away from home, while the hard top is in the garage. I think the Carbonized Gray is going to be okay for me.
GordoJones
TN
Explorer
Ford removed the Body Color Painted Hard Top which WAS an option on all models.
It appears that the 2 Door Black Diamond will only be available with the Molded in Grey Hard Top.
Ford Bronco Modular Hard Top on Black Diamond? Screenshot (2415)
wvmtneer
‘Merica
F-150
Can go dual tops for a ridiculous $3,700.
Carolina Jim
Highlands
2021 Bronco 2-door
the web site you illustrated is Canadian. But the USA site was the same...I clipped/pasted from it sometime in july.
Ajusaf
AJ
VA
As long as I get do this with the gray version and store it in the trunk space then I'm happy
