Morimoto XRGB Headlights | IN STOCK
Jfuller44
Green Bay, WI
Bronco, Honda acty
Where in the app did you find a way to set color values?
When you're in your own custom color option there is this little box that comes up to the left of the color wheel...
Ford Bronco Morimoto XRGB Headlights | IN STOCK Screenshot_20230201-213450~2
When you tap on that a larger slider will show up
Ford Bronco Morimoto XRGB Headlights | IN STOCK Screenshot_20230201-213455
LightRefined
Randy
Vicksburg, MS
2022 Ford Bronco Outer Banks
Dr.Ross
Kyle
Phoenix
dreadfulobjects.com
2022 Base Sasquatch 4 door
Mine are awaiting pickup at the local FedEx office. We’ll see this weekend if it’s a one beer job!
Bird Dog Off Road
Jody
Phoenix, AZ
www.youtube.com
Picked mine up yesterday and putting them on tomorrow.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
We never had s
Hey @4x4TruckLEDs.com, any updates on shipping for the XRGB's? 😇
1/2 the orders went out this week. The remainder will ship Monday/Tuesday.
We're just making our way through all the pre-orders that were placed with us.
LightRefined
Randy
Vicksburg, MS
We never had s
Gotcha, thanks for the update ☺ can't wait to get mine!
Baerkeeper
Los Angeles
2023 2dr Basequatch | 2020 Miata RF
Planning to install mine tomorrow and this may be a silly question but do they need to be aligned during install? Or just replace and bolt on?
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Yes you always want to re-align your headlights whenever you make changes (new lights, new bulbs in the old days, etc...)
It's easy to align them.
Park 25' from a wall (a blank wall, level ground)
Measure from the ground to the center of the top projector (which is your low beam). Make a note of this #
Now mark that # from above, minus 2" (so if the measurement was 18" mark 16" on the wall).
Do this on the left/right side.
Now just turn the screw until the top of your beam touches that.
Use a philips screw driver on top of the housing, there's a spot you insert the screw driver and turn.
Lights will look kinda like this:
Ford Bronco Morimoto XRGB Headlights | IN STOCK 1675483340941
evgenyvasenev
Evgeny
Gig Harbor, WA
vasenev.com
Ford Bronco Badlands
Which line (top or bottom) should be on the mark?
Dr.Ross
Kyle
Phoenix
dreadfulobjects.com
Ok I’m installed, the only issue I ran into was on the passenger side I had to add a few washers in addition to the spacer, and I still think it’s a little low. But, I do have a question.
When using the turn signal after I switch it off, the drl takes about 2-3 seconds to turn back on. So the other one is on by itself. Is that normal?
Ducati1098
2022 Bronco Wildtrak, 2012 Ford Fusion
Ok I’m installed, the only issue I ran into was on the passenger side I had to add a few washers in addition to the spacer, and I still think it’s a little low. But, I do have a few questions/concerns.
first, when using the turn signal after I switch it off, the drl takes about 2-3 seconds to turn back on. So the other one is on by itself. Is that normal?
second, can these be adjusted left to right, or only up/down? They seemed to each be aimed a little outward.
Otherwise, they’re looking good.
I have the same issue with the turn signals. It’s honestly kind of crazy how long it takes the drl to come back on after the turn signal shuts off. Definitely a design flaw in my opinion. But I doubt there’s anything that can be done about it.
Also, as far as I know, there is no side to side adjustment.
Dr.Ross
Kyle
Phoenix
dreadfulobjects.com
Dr.Ross
Kyle
Phoenix
dreadfulobjects.com
I measured them again and the distance between them was true, so just a trick of my eyes.
