Mountains2Metal Antenna/Flag Mount
Mountains2Metal
Nick
Eastern, NC
2012 F-150, 67 Bronco, 94 Range Rover
Check out the new flag/antenna mount from Mountains2Metal! Our bracket is currently available for the Driver's Side and will be available for the passenger side very soon. There is so much wasted real estate on the driver's side of the tailgate so we decided to go with this route first. To go along with the flag mount, we are offering a bundle that comes with a 4 foot fiberglass pole, rotating clamps for a flag, a quick release flag mount, and a heavy duty spring to help with those highway speeds. The nice thing about the quick release flag mount is that it is easy to install or take off. The flag stores perfectly under the back seat of the 4 door bronco. If you decide to use this as an antenna mount, we offer holes along the edge for wire management with zip ties.
https://mountains2metal.com/tailgate-flag-antenna-mount-bracket/
Flag/Antenna Mount Bracket, Driver & Passenger side.
  • Made in the USA!
  • 12ga HRPO Steel
  • Powder Coated Black
  • Works with OR without Tailgate Reinforcement Bracket
  • Utilizes factory bolts and holes.
Destination Bigfoot Bronc
Jamie
Richmond, Virginia
2019 F150 Limited, 2022 Bronco OBX Cyber Sasquatch
Best option available. There was something that was irritating me about having that wasted space on the left side of the tailgate. This filled in the gap perfectly and added a great spot to add something useful. Perfect for custom flag, dune flag, antenna, or led whip. Also has a built in channel to run wiring and locations to attach zip ties to keep wires tucked out of the way.
Here's a video I put together of the install. Super quick and easy.
