New Morimoto triple fog light kit installed
Just_Jay_Kng
Jayson
Dallas
All hxb bulbs in wide beam pattern
2 sets of yellow and one white set!
Crazy amount of light output!!
here are some screen shots of the light output from the video, Yellow shot is just the yellow fogligths. The white shot is with a set of diode dynamics ss3 max driving lights turned on as well. (why the tower is lit up)
Ford Bronco New Morimoto triple fog light kit installed img_6631-
Ford Bronco New Morimoto triple fog light kit installed img_6635-
TXAG96
Tyler, Texas
'20 Bullitt, '01 Boxster, '87 TBird Turbo Coupe
can you select white or yellow independently as provided?
Just_Jay_Kng
Just_Jay_Kng
Jayson
Dallas
Yes I ran the yellows on one aux switch and the white on another six switch.
Or you can wire them all separate. Or all together.
The triple harness from Morimoto will only allow you turn them all on at once. If you want anything different you need to run a different harness for each set of lights.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
We actually have a kit with Morimoto 4Bangers (we were the first to offer this) which includes our own harness that lets you put each pair on it's own switch
https://www.4x4truckleds.com/morimo...-w-kr-off-road-brackets-for-2021-ford-bronco/
Just_Jay_Kng
Just_Jay_Kng
Jayson
Dallas
4x4TruckLEDs.com
Adam
Lindenhurst, NY
I think the link is broken… does your kit wire direct into the aux switches without an additional relay?
Link works. Yes it doesn't require relays. Our harness connects the 3 pairs of lights to 3 different upfitters. Real easy install
fallguy
Tennessee
2020 Defender, 2022 Outerbanks SAS, 1968 Mustang
I didn't see an install video on these or the pillar lights on youtube. Is there one? I am looking for no relay.
Just_Jay_Kng
Just_Jay_Kng
Jayson
Dallas
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Our kits do not reqiure a relay. Our plug and play harness is included. They plug right into the back of the lights and you just need to crimp the harness onto your upfitters. We have pre-terminated weatherproof/heat shrinkable connectors on our harness already.
Bolts on to your truck with 3 bolts in the factory HD Modular bumper opening. Just like any triple fog kit we sell
4x4TruckLEDs.com
Adam
Lindenhurst, NY
If you don’t want a relay use these harnesses for diode dynamics.. you will need one for each pair of lights but they will wire to ground and straight to your powered Aux switches https://www.diodedynamics.com/oem-auxiliary-switch-dual-output-2-pin-wiring-harness.html
Actually we make a harness that is almost plug and play for 3 pairs of lights:
Deutsch 2-Pin (Diode Dynamics Non-Backlit, Rigid D-Series, KC and Morimoto 4Bangers):
https://www.4x4truckleds.com/crysta...ors-diode-dynamics-rigid-industries-morimoto/
Ford Bronco New Morimoto triple fog light kit installed 1658784122447
Ford Bronco New Morimoto triple fog light kit installed 1658784126465
Ford Bronco New Morimoto triple fog light kit installed 1658784132767
Just_Jay_Kng
Just_Jay_Kng
Jayson
Dallas
fallguy
Tennessee
Awesome, thanks. A discount for buying both the Pilar and fog set at once? Or coming up sales?
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Use coupon code FOGS and you'll save some $$ off the kit.
cobralsc
Joe
TX
04 Mini / 01 Viper
@Just_Jay_Kng I know this is an old thread so please forgive me. I have my heart set on the 4bangers. I can't decided between NSC or the HXB (in yellow). I know the HXBs use white leds with yellow lens vice NSC using yellow leds. My question is do you like the yellow shade that the HXBs produce? Do you find them too bright for rain? Now that it has been a year, are you still happy or would have done anything different?
2fast4u
Rancho Cucamonga CA.
Shelby GT500 and Bronco Wildtrak
How is the output and how do these stand up vs the Baja Design squadron pro's?
