- Rob
- Jul 29, 2020
- 10
- 1,342
- 2,844
- South Salem, NY
- 2018 Jeep Wrangler Moab
- Undecided
That doesn’t look cheaphere you go
already got one of those.here you go
Topeak Unisex's Joeblow Booster Floor Pump, Black, One Size https://www.amazon.com/dp/B081PTDCZ3/ref=cm_sw_r_cp_api_glt_fabc_1BX7P30ZZN6PXKQA0S5Balready got one of those.
and a regular air compressor in the garage.
I'm just looking for something I can bring with me in the car.
Over 200 for a bike pump!!!Topeak Unisex's Joeblow Booster Floor Pump, Black, One Size https://www.amazon.com/dp/B081PTDCZ3/ref=cm_sw_r_cp_api_glt_fabc_1BX7P30ZZN6PXKQA0S5B
here you go. It's free and may only cost you your lifealready got one of those.
yes. you can pull more amps directly connected to the battery.is there a big difference between using the cigarette lighter or the 110v outlet in the back or the battery?
thx, I mean I kinda figured that. Otherwise why would the offer it. Plus, duh.yes. you can pull more amps directly connected to the battery.
internal ac transformer is less efficient, too.
when i was reading up on them, people were saying the cigarette lighter models weren't capable of filling larger tires. I assume that means they'd overheat before you could get 30lbs in a bigger tire.thx, I mean I kinda figured that. Otherwise why would the offer it. Plus, duh.
But maybe I was missing something.
Smittybilt 2781can anyone recommend a cheap, but decent portable air compressor? I just want something that I will use occasionally when off-roading on sand.
that's the one I said, but he said it was too expensive.Smittybilt 2781
For reals. People think I'm made of money? I'm about to drop $45k on a car whose roof will fall apart. Can't just go pissing money out the window.that's the one I said, but he said it was too expensive.
Look who you are talking to PowPow...For reals. People think I'm made of money? I'm about to drop $45k on a car whose roof will fall apart. Can't just go pissing money out the window.
I need it to buy felt bumpers. Or clear tape. Or glue to keep my panels together.
Priorities people.
I've been thinking about getting one of these cheap ones from Harbor Freight. Now, full disclosure, I didn't buy these, but they were something I've been looking at as a temporary solution until I figure out what I want to do.can anyone recommend a cheap, but decent portable air compressor? I just want something that I will use occasionally when off-roading on sand.
You found it that's the one I have. Bought it for the quads, ended up using it mostly for Mustang tires over the winter, 1 had a slow leak. Thank God those tires got replaced eventually.12VDC 15A Cigarette Outlet 0.25 CFM
https://www.harborfreight.com/12v-100-psi-high-volume-air-inflator-63745.html
