OEM Soft Top compatibility?
5PC24
Pacific NW
2023 Bronco
When a customer orders a dual-top what soft-top do they get? Do they get the Webasto or BestTop?
Info I had indicated it was the Webasto as long as it was the dual top option. If you ordered the MIC hard top option and one of the other soft top options then you got Bestop
derichio02
Bo
Southern California
Bronco Badlands, Maverick, Tesla M3, F250 Tremor
Any way to tell the specific manufacturer of a soft top? I’d be down to have one for my Raptor as well
derichio02
Bo
Southern California
I think that there is some confusion here. Maybe it's just me.... haha There are technically two "Ford" soft tops. One that's made by a company named Webasto who also makes the hard top. The Webasto soft top is ONLY available by ordering a soft top Bronco from the factory. The second soft top is the soft top that Ford sells as an option to purchase individually. This soft top is made by BesTop
The Webasto top fits the Raptor 100%.
So in theory if I buy a takeoff oem, from the factory, soft top from another 2022 Bronco then it will fit on the Raptor?
Does this interfere with or require removal of the center brace or are the mounting points behind the brace/bracket?
erniecombs
Ernie
1974 Bronco
Mind helping me with a little issue I'm having....
I bought a 2021 OEM soft top off someone for my late 2022. The mounting holes on both sides do not line up at all.... Can you maybe help out with your experience...
I just posted the issue on the forum. Am I missing something...?
https://www.bronco6g.com/forum/threads/soft-top-mounting-holes-changed-on-newer-bronco.68641/
Yes you are just missing the brackets. The top two bolts on each side mount to a bracket and the bottom bolt on each side mounts to the body. This also happened to me last summer. You just need to ask that person for the brackets. I tried to look up a part number for the bracket and was not successful then.
Ford Bronco OEM Soft Top compatibility? IMG_1416
erniecombs
Ernie
1974 Bronco
Yes, if you have an OEM take off top then it will fit with out touching any of the raptor bracing.
erniecombs
Ernie
1974 Bronco
Not that I am aware of other than the tops look and operate very differently.
erniecombs
Ernie
1974 Bronco
Can you share your source?
Ryan Feilner
Ryan
Omaha, NE
Thank you so much!!! Thought I was in trouble there! I’ll get that!
5PC24
Pacific NW
2023 Bronco
It was what my dealer had told me when I wanted to add the dual tops option to my Wildtrak order.
Dual Tops = MIC Hard Top+ Ford OEM Soft top with squared back
Top, Retractable - Full Twill Soft = Bestop with slant back
erniecombs
Ernie
1974 Bronco
I really think we need to verify what the dealer is saying. The frame for the Webasto top is huge and I'm having a hard time seeing how the top and frame for this soft top could even fit into the Bronco with the hard top on. I feel that it would be something that would require a pallet and shipped separately.
The BesTop is much less complicated and the box could fit inside the Bronco.
So the thought of logistics just makes me question what this dealer is saying.
derichio02
Bo
Southern California
Any Pics to show the difference? I am going to pursue a top but want to make sure I am getting the right one.
Michael Grasso
Indianapolis
2025 Ford Bronco
Ernie thanks for the info and clarification!
mg
derichio02
Bo
Southern California
Hey Ernie is there a difference regarding Raptor fitment in the 2021-22 Factory Soft Top and the 2023 Factory Soft Top? I know the 2023 is a bit different visually (Pleats at the top to side transitions) but not sure if any hardware was changes that would affect Raptor fitment.
