Jeep - “ It’s just going to be a desert runner like the F150 Ra..... ?”
y'know, likeJeep - “ It’s just going to be a desert runner like the F150 Ra..... ?”
Early Bronco on the screenwhat am I looking at here?
Sounds like a plan. Where can I do that?I just think a lot of the negative Nancys on here need to actual DRIVE THE VEHICLE before they decide they won't buy one.
are you talking about the configurator?Long time lurker in this great forum. Much appreciated from a novice like myself.
Wish we can play around and actually build different versions. Do you think that will be available weeks before those who reserved get to play around?
Yes. Did I miss that?are you talking about the configurator?
it isn't available for 2 and 4 door models but you can configure the bs. config for the 2 and 4 door will be available in about 5 monthsYes. Did I miss that?
A lot of modern turbo cars will just pump the oil through the turbos for a little bit then shut off the electric oil pump themselves after you turn the vehicle off so you don't have to worry about it.Last time I had a Turbo was on a late 80s Supra. Back then had to let it run about a minute to minute & a half at start up & before shutting the engine off after driving. Currently have naturally aspirated 3.7 Infinity Q60. Just wondering if modern Turbos recommend the idle time for better/longer Turbo life?
Man, I can't even afford to go to Rivian's website. Buying a Rivian is out of the question for me.No! I may go get a Rivian, actually
edit: ehh, probably won't get a Rivian, but may have to set up dual batteries or something for aux power
they charge rent for typing out there name. i would delete that if i were youMan, I can't even afford to go to Rivian's website. Buying a Rivian is out of the question for me.
There's something about those rims....can't quite put my finger on itis this a model i can buy? i sure hope so!!
steelies from the base, black diamond or bsThere's something about those rims....can't quite put my finger on it
