Outer Banks Grille Question
flowingaway
flowingaway
Tennessee
2016 Toyota Tacoma 2023 Bronco Badlands
I really appreciate this discussion. This is far and away the most detail I've read about this subject.
flowingaway
flowingaway
Tennessee
So check out this picture. Notice the 8046 part looks a little different depending on which grille it's paired with.
My thought is that if someone really wanted to do a swap properly they would order their grille of choice AND the corresponding bracket 8046. It looks like that 8046 part is what is going to provide that hood latch mechanism protection.
Of course this is purely speculation as I don't have my Bronco yet.
Ford Bronco Outer Banks Grille Question 2022 Ford Bronco Raptor Warthog Grill 1
Slimpickens
Apopka, FL
FJ Cruiser
In addition to my post above - Notwithstanding, I still prefer the OBX grille over the WT because it's concave. The WT grille is flush and gives the front a snout like appearance when not head-on (something most dont think about). But I am considering maybe some type of black mesh behind the OBX grille openings if its subtle and covers up the stuff behind it.
Post a pick if you do please, interested in what that would look like!
JohnnyBronco
Pennsylania
X4
FWIW, Big Bend models have the same piece in the middle.
And to think all along I thought it was just another grill shutter that was always closed when I looked
j_anderson
Jason
Fort Wayne, IN
www.instagram.com
I want to install Raptor style grille lights but that latch protector is a real bummer. I suppose cutting an opening for whatever light to pass through isn't out of the question .
niterider006
State College, PA
Ford Bronco Outer Banks Grille Question 1644271157503
tropical2020
Tropical
AZ
I just joined this forum today... I'm about to get either the Badlands (BL) or the OB (outerbanks) bronco sport. I love the navy pier seat coloring and I'm trying to see if I can get the navy pier seat coloring on the badlands model. It won't let me add the pier navy seats to the badlnds model.. only to the outerbanks model when I enter in the build I want on the ford website.
Sorry to make myself look dumb... but when you guys write "OBX" are you referring to the outerbanks grille?
I like the grill on the BL (the egg crate-like design with gray finish ) and I'm trying to get the guy at the dealership to order me the outerbanks with the badlands grill...
From reading this thread it appears most people prefer the outerbanks grille? Meaning the OBX grille? Thanks!
PS: I am sill conflicted if I want the BL or the OB. I will never go off-roading other than light camping. Hence why I'm leaning towards OB model... but I don't like the grille on the OB.
Ford Bronco Outer Banks Grille Question outerbanks-grille
Ford Bronco Outer Banks Grille Question badlands-grille
Slimpickens
Apopka, FL
FJ Cruiser
I think you’re in the wrong forum… check out https://www.broncosportforum.com/
tropical2020
Tropical
AZ
Whoops my bad I didn't realize that sorry.
jmcl
Jason
Dallas
Jeep Wrangler 4-door
Has anyone attempted to install the Raptor type lights on the outer banks grille? I see the photo posted earlier of the round ones which in my opinion doesn't look quite as good.
Grey Pony
Gerald
Waelder Texas
2019 F-350 DRW Lariat2022 Outerbanks Bronco
Has anyone attempted to install the Raptor type lights on the outer banks grille? I see the photo posted earlier of the rounds ones which in my opinion doesn't look quite as good.
Following.......
jmcl
Jason
Dallas
Below is some pics of my install of led lights from Oreily auto on my outer banks. They look and fit great and hope they last. I drilled a small hole in center grille to run my wire through otherwise the light would stick out to far. Simply spliced wire and soldered back together. Ran wire back to fuse block and tied in using ad a circuit to spare circuit that comes on with ignition. Lights install by using provided 3M provided tape.
Ford Bronco Outer Banks Grille Question 20221016_161955
Ford Bronco Outer Banks Grille Question 20221016_140106
Ford Bronco Outer Banks Grille Question 20221016_160705
Ford Bronco Outer Banks Grille Question Screenshot_20221017-061550_Chrome
bentontl
Travis
Missouri
I ended up using a fuse tap and some amber LEDs from Amazon (links below). I used 3m heavy duty adhesive to attach the outer 2, sure seems solid, the center one is attached with screws since there is actually something to mount to. Total cost was less than $30.
Micro2 Fuse Tap (5A 10A 15A) and Fuse Puller https://a.co/d/cmap0n5
3Pcs 4" Inch Amber LED Center Grille Running Marker Light Kit Smoke Lens Pro Grille https://a.co/d/3m9VKcn
Ford Bronco Outer Banks Grille Question 20230209_163653
Deleted member 49144
Guest
Okay pardon this question if it’s already been answered, but I’ve been seeing so many “matte” versions of bronco grilles. I have an outer banks and it’s gloss, and that’s what I see on other outer banks as well. Does the outer banks grille come in any other finish other than gloss?
if I wanted a matte finish grille, I’d have to switch to another grille from another model? I do like the design of the outer banks.
flowingaway
flowingaway
Tennessee
Correct. The design of the outer banks grille, but in the molded in color (matte gray) color comes with the big bend trim.
