Overhead Storage Idea
Tricky Dick
Dick
PNW
www.TD-Distributing.com
I've begged anyone that will listen to make these for us but no takers yet. I realize it's not exactly what you asked for but IMO it's the best solution for overhead storage.
Ford Bronco Overhead Storage Idea 191784-add1-lg_0
joeb
Pennsylvania
FJ Cruiser
I'm digging that !!
That is the concept I'm looking for -- from drivers door to passenger.
Tricky Dick
Dick
PNW
I'm digging that !!
And only $100 for Jeeps so pretty reasonable. (but probably $300 after the Bronco tax is added)
rblock50
Ryan
Orange County, California
VW, Bronco
I wanted to install a mesh-like storage along the top of the Bronco that I could use for extra storage and easily remove. I came up with the following and the total cost was $34, and the color of everything matches with the "MIC/Black" of the interior.
1. Set of D-Rings (need 4): $8
- These are be used to attach the net to the car
- They fit perfectly by using the 8MM bolts that were already in the car. It's the same bolt holes I used for my grab bars.
- I attached the D-rings to the 2nd and 5th bolts.
- https://www.amazon.com/dp/B01DEFD3N8?psc=1&ref=ppx_yo2ov_dt_b_product_details
Ford Bronco Overhead Storage Idea D-Rings
Ford Bronco Overhead Storage Idea D-rings-installed
2. Swivel Snap Hook (need 4): $7
- I needed it to fit a 1" strap and these seemed pretty good.
- I removed the buckle, attached the swivel hook, and then reattached the buckle
- These will attach to the stap of the net and then clip onto the D-Rings that were installed in the Bronco.
- https://www.amazon.com/dp/B00MB96TG2?psc=1&ref=ppx_yo2ov_dt_b_product_details
Ford Bronco Overhead Storage Idea Strap-Hook
Ford Bronco Overhead Storage Idea Strap-Hooks
3. Mesh Net: $19
- This has some zippers and straps and seems very sturdy.
- It has two small compartments plus the larger middle zipper section, as well as what can fit on top.
- https://www.amazon.com/dp/B0B6VKXBVJ?psc=1&ref=ppx_yo2ov_dt_b_product_details
Then I simply attached all 4 swivel hooks to the D-Rings that I installed and adjusted the tautness of the straps. I'll eventually cut the extra strap off once I know for sure what the max sag I want (i.e. the most stuff I want to put in it without it hitting my head above).
Here is the large pocket with zipper. There are two smaller compartments in the middle too.
Ford Bronco Overhead Storage Idea net1
Here the straps are more "loose" so that I'd have more room for jackets and such on the top of the net. It doesn't seem touche anyone's head, but it could limit my visibility with the rearview mirror. I'll have to check that next time.
Ford Bronco Overhead Storage Idea net2
Here I have straps tighter so that it fits more snug to the top. it shouldn't interfere with the rearview mirror view.
Ford Bronco Overhead Storage Idea net3
I think they should be "airbag friendly", right?
N8RsLBFE
Nate
21 First Edition Bronco
I just want something small above the switches for sunglasses, etc. And that doesn't cost $100+
tourproto
Portland, OR
2004 BMW 330i, 2022 Bronco BL 4DR
3. Mesh Net: $19
Nice job. I have been noodling ideas to do this as well.
I found a cool Bronco Attic Tray, but it is overkill for what I need (https://puravidaoffroad.com/shop/ols/products/ford-bronco-attic-tray)
What I like about yours is looks like it will provide the "front" mount point for a 5-foot fly rod case or a rifle case. I was going to just lash cordura straps over the rear roll bar for the "rear" mount point and just "slide" either the rod case/gun case along the roof line.
Thanks for doing the homework on the nuts and bolts for the mesh netting.
joeb
Pennsylvania
FJ Cruiser
How about this
Ford Bronco Overhead Storage Idea 20230622_070805
