Oversized PPE Aluminum Transmission Pan - Fit Confirmed
swamp2
swamp2
The context here is "teach me" A deeper pan always meant lowering the pickup many years ago. Is that not relevant here? If it isn't, why? I know somebody out there knows why.
If I get you, your concern is reduced ground clearance?
That isn't relevant here as the increased pan depth only fills empty space between the factory pan and skid plate.
swamp2
swamp2
While we are at it @Ducati1098 what are thoughts on Ford specing so many new screws and nuts in this procedure? Head bolts, or torque to yield, sure, replace them. Sway bar mounting and the others in the guide you posted as one time use?
Ducati1098
It’s a ridiculous pain in the ass. I think Ford does it from a liability stance.
If it isn’t torque to yield, I see absolutely no reason it cannot be reused.
Breptar
Max
Los Angeles, CA
That was interesting to me too. It states to toss them, but I didn’t see a part number to replace them. Did you happen to reuse yours when doing this, or did you purchase all new ones?
swamp2
swamp2
swamp2
swamp2
thank you, and thanks to you I have gone down this rabbit hole and now I want to change all fluids and do this at the 1k mile mark! LOL
It's extremely conservative, but what the heck. Baby our babies. And then beat 'em up. I'm heading to Glamis this weekend.
vrtical
Doug
GSMNP, TN
Fords
I always reuse the majority of bolts on Fords never ever had a bolt failure, but usually use the torque specs so that makes a big difference. The only time I deal with tty bolts, like heads, usually toss em and convert to ARP versions.
Dialtone
Twilight Zone
Bronco Big Bend Mid
Sorry. I wasn't clear. A deeper pan usually requires extending the pickup tube downward in to the now deeper sump. I didn't see that mentioned here and was wondering why that wouldn't be necessary. Bear in mind this is from an old small block Chevy/Ford guy that ran deeper, baffled pans on most of his stuff. TIA
swamp2
swamp2
I am not positive on this. However, with a deeper pan combined with a larger fluid volume, I would guess the design places the distance between fluid intake and free fluid surface the same, thus not requiring any mechanical modification.
Ducati1098
That’s correct. Pick up location doesn’t need to change just because the pan is deeper. As long as the fluid level is set correctly with the additional capacity, it’ll work the same as a factory capacity pan.
Dialtone
Twilight Zone
Bronco Big Bend Mid
Great. Thank you both.
