Mishimoto and PPE pans were considered but neither had confirmed fit for the Raptor. I think both our 10R60 and 10R80 trannies can use the same pan less the fit of nearby components. Unfortunately, Mishimoto would not respond to repeated inquires under their sponsorship program, which basically gets one a free part for confirming a new fitment. PPE responded quickly and were helpful and flexible if a return was needed. That said I did pay full price.
I went with the increased depth/volume pan which provides an additional 1.75 quarts of fluid capacity.
PPE 328053600
As noted in the detailed instructions provided by @Ducati1098 , the sway bar disconnect motor does need to be dropped and the fit is tight. The fill level on the dipstick for the Raptor is the same as non Raptor, between 3 and 4, with fully up to temp fluid.
As noted by @CarbonSteel here the PPE pan is very nice. I went with black with brushed silver fins.
Obviously benefits here: easier servicing via magnetic drain plug, better cooling, more fluid, less chance to warp, additional impact strength (even if protected by a skid).
Here is the stock pan vs. PPE and the beauty installed.
No idea if this deeper pan will fit non Raptor.
Ref trans filter part number: HL3Z7A098A
A̶l̶s̶o̶ n̶o̶t̶e̶, t̶h̶e̶ f̶i̶l̶t̶e̶r̶ s̶e̶a̶l̶ (̶n̶o̶t̶ p̶a̶n̶ s̶e̶a̶l̶)̶ i̶s̶ n̶o̶t̶ a̶v̶a̶i̶l̶a̶b̶l̶e̶ a̶s̶ a̶ s̶e̶p̶a̶r̶a̶t̶e̶ p̶a̶r̶t̶ a̶s̶ i̶m̶p̶l̶i̶e̶d̶ i̶n̶ t̶h̶e̶ i̶n̶s̶t̶r̶u̶c̶t̶i̶o̶n̶s̶ l̶i̶n̶k̶e̶d̶ a̶b̶o̶v̶e̶. My dealer parts guy said this seal is only available as a part of the entire trans pump.
Update: Filter seal part number as provided in post below is 7T4Z-7Z302-A
PPE 328053600
