Parking sensors going crazy after new bumper install
TahoeTexan
Tod
Reno, NV
2022 Bronco OBX
I installed the Rough Country front bumper over the weekend. Afterwards the parking sensors are going crazy. Sometimes I get message about the REAR sensor being blocked and sometimes it's the attached photo. I did a soft reset on the Sync4 system, but it did not help.
Any other suggestions?
Havoc1
07 F250, 20 Accord Sport, 21 HD
Clean the sensors? Damaged sensors on reinstall? Make sure they're all plugged in and no damaged pins? Pinched wires?
TahoeTexan
Tod
Reno, NV
2022 Bronco OBX
I did clean and they were gently installed. A pinched wire is possible I guess.
Is there a process to reset the sensors?
Havoc1
No, they're plug and play
Last Ride Bronco
southern USA
Nissan pup
I saw a video, I think Town and Country Ford on YouTube, where they talked about having to reset the sensor system with a similar situation. You might be able to call T/C Customs at Town and Country Ford in Alabama and just ask. They are friendly folks. I imagine they could tell you.
Lak34ers
Troy
Seattle
Ford Bronco Parking sensors going crazy after new bumper install PXL_20220614_035310906
Can you post pics of the installed bumper. Thoughts on quality and install?
TahoeTexan
Tod
Reno, NV
2022 Bronco OBX
I will once I get back from a road trip and wash off the million bugs.
The installation was straight forward and pretty easy, even with no help. The driver side wing/bumper end did not line up perfectly but still installed fine.
This is a relatively light duty bumper. But if you are looking for something aftermarket with light options, parking sensor and ACC compatibility at a very reasonable price - this one is worth a hard look.
I'm excited for the rear bumper as well. I caught a glimpse of it when they accidentally posted it on their site for a short time, then took it down
Porters.ride
Chad
Newington Ct
2021 4 door soft top
Did you ever figure out your sensor issue? I replaced my back bumper, and I’m getting sensor fault as well.
TahoeTexan
Tod
Reno, NV
2022 Bronco OBX
I mostly have it figured out. All I really had to do was reach up from behind the bumper and push/ensure all 4 sensors were seated.
I have the RC bumper too but haven't installed it yet. When I do, I'll ensure they are all seated well and will probably put a little silicone around them to ensure they stay seated.
DJC4
Dan
Cincinnati Ohio
22 Bronco, 20 Golf R, 96 911 c4s, 04 BMW M3
WD-40 did the trick!….the main connector would not fully seat and hence the error!!! Little spray of oil and click…everything works!!!!! I need to check the internet earlier in my frustration cycle!
Thanks for the post!
