Pictures of 4 door - with 35's and no lift ? Which wheels and tires did you choose ?
Broncolli
MD
'21 Back Diamond 4 door MIC
Pictures of 4 door (NON-SAS)- with 35's and no lift ? Which wheels and tires did you choose ? Any issues ?
Bikeric
Tulsa
1984 4Runner (For Sale)
Here's a picture of my wife's old Beg Bend non-Sas with 315x70R17 tires (almost 35's) and zero lift. Had some 17x8.0" zero offset wheels from a 4Runner project that fit just fine with the use of hubcentric rings.
JDoc92
Tim
Northern Illinois
2017 Honda Ridgeline
I did eventually put on coilovers but here it is pre-lift. 35x11.5x17 on Everglades rims.
Fordified1
Bob
Mid South Texas
35x12.50r 17’s on 17”x9” +13 offset wheels.
Will be buying the Ford Performance 2” lift coilovers. Because we do some serious wheeling and they might rub when articulated. The clearance is fine for a mall crawler.
Ford Bronco Pictures of 4 door - with 35's and  no lift ? Which wheels and tires did you choose ? 725B4CF5-3038-41B0-A143-36A8C947830C
Ford Bronco Pictures of 4 door - with 35's and  no lift ? Which wheels and tires did you choose ? 92D485E2-355E-4A80-918D-64E98289B0E3
Dmorty217
Derek
Venice FL
Camery
Here is mine day 2 before all the other mods. Had to remove the crash bars. 315/70/17 toyo open country
dbattle
Northern VA
2011 Toyota Prius
315/70/17 Nitto Recon Grapplers. +18 wheel offset. Zero lift. Hubcentric rings (a must). I love the ride and the tires aren’t loud but still look aggressive. I would do it again tomorrow.
Ford Bronco Pictures of 4 door - with 35's and  no lift ? Which wheels and tires did you choose ? SRP06229Bronco_2023
dbattle
Northern VA
2011 Toyota Prius
Also this is the exact wheel I got (same specs)
Ford Bronco Pictures of 4 door - with 35's and  no lift ? Which wheels and tires did you choose ? IMG_2924
