Power widow’s defective
Robert
Houston, Texas
2023 Ford Bronco
Power windows go up and right back down! 3rd time in the shop for obvious defect on sensor. Ford will keep repairing but hoping to here from someone else what they have found out.
contented
Karl
Central Fl
BMW M2 Competition
MotoVexGT
Ahnamataeus
Seattle
Ford Bronco Badsquatch
I have the same issue on the two right windows. I'll try the reset steps in the articles.
Bigmoose
Jon
RI
2019 Flex Ecoboost Limited
There is a door module update that significantly improves this issue. Ask your service department to check for module updates.
BroncMO
St. Louis
2015 Jeep Grand Cherokee
Push the window down button, hold for 10 seconds at bottom. Pull the window up button, hold for 10 seconds at top.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi there. If you'd like to, go ahead and send us a private message with your VIN and dealer info and I’ll look into this window concern. Thanks!
Murfman
Colorado Springs
2021 WildTrak, Cyber Orange soft top
Mine does it when the WX changes. They said it was swtich and replaced it but it still does it. I say its the sensor.
Robert
Houston, Texas
2023 Ford Bronco
Robert
Houston, Texas
2023 Ford Bronco
Rob, welcome to the forum. It’s probably not the sensor. My driver’s window has done it several times. I do this - https://www.wheelsjoint.com/ford-bronco-auto-windows-not-working-how-to-reset/. One time the reset procedure didn’t work, but after a few days it started working properly on its own. Go figure.
Enjoy your new truck. Take care.
Thanks. Ford dealer reprogrammed the system and it’s working for now.
omi205
BoJack
Austin
Happened to me while in the parking lot at whataburger last night. First time. Was shocked. Luckily I read about it on the forum a few month back. Quickly looked up the procedure. Completed the steps and the front passenger window was back working. It was rolling up about 3/4 of the way, then would stop, then would roll down but not all the way. About 2" would remain left up. And it would stay there. I did the procedure twice and it worked. Only at 7.8k miles. 2023.
Buxton Bronco man
Don
Maine
2022 Bronco wildtrak
My 2022 wildtrak has done this several times.
AK SNO RIDER
Ty
Alaska
Spent 10 min last night trying to get one of my windows to roll up. Relearn procedure had no effect. Just when I was fixing to give up and clear the snow off my truck it suddenly started working.
Ford problems...🤦
rayhil67
Ray
Douglassville pa
2012 JK Sahara 2006 hummer H3
Ford problems...🤦
This is the second winter in a row that I had this issue, funny thing is I've never had it once during the warmer months. (and no, icing is not the issue dry and cold)
Spent 10 min last night trying to get one of my windows to roll up When this happens I have to open said door that window will not go up, then put window up and hold button for 5 seconds then close door. The problem always comes back, Im going to look into this " door module update' fix next oil change
