Starting off we named our Bronco Snowball because of the snowball effect that took place. We planned on getting the black diamond and not upgrading it too much because it was an all around capable rig from the factory. Coming from a desert back ground and having long travel go fastissshhh rigs i knew it was going to be hard to keep stock and with the Wife's approval before we even picked up the bronco we had parts waiting.
With only 200 miles on her we installed Four wheel parts upper control arms, rear track bar, fender deletes(for now) and Coil overs in all four corners. Next we installed 37' KM3 with KMC Grenade Desert beadlocks. I have a arb dual compressor waiting for install as well.
So far she handles great. We do have rubbing at full bump in the rear but nothing up front. I noticed when turning half lock in either direction going slow it acts like the ABS is trying to turn on and the pedal pulses. Im thinking it has to be something with the sensors on the window not being adjusted since the bronco is taller now. Going to have to take it in to ford and see what they say unless someone has a recommendation.
