dmarked00
Carl
2022 4 Door
vanlab
SW washington
2022 Wildtrek, Ford transit, 2021 Bronco sport
The JCR support brackets are different and attach to the sport bar and the top and require you to remove it. I’m choosing to install both the RCI and the JCR brackets together. I hope that helps any confusion in my decision to install them at the same time when I’m ready to complete the project.
I quoted wrong person, but he was looking for directions to install the RCI brackets.
Like you I am going to install the RCI bracket and the JCR
Saltwater Junkie
Sir Fishin
Tar Bay,Va.
99 7.3 F350, 22 7.3 F350, 23 2.7 BRONCO OBX
just patiently waiting to see their solution.
And patience are running thin..anyone heard from RCI or installed their "fix"..Is it time to look at other options?
vanlab
SW washington
I bought JCR roof reinforcement, seems like the only solution, my roof was pushed in so bad that water runs inside
Saltwater Junkie
Sir Fishin
Tar Bay,Va.
For those interested..
Halloween sale in effect. 🎃 👻 🧛‍♂️
Cbgarrett
Bronco badlands
Picked up the RCI half rack for my badlands. Fit and finish is top notch and very sturdy once installed.
RC Bronco
Rob
Kansas
'22 Ford Bronco, '97 Geo Tracker
Ford Bronco RCI Modular Roof Rack NOW AVAILABLE! rack
it’s interesting to see your middle panel is slightly tilted at the front without the full rack. Do you know if it was tilted prior to installing the half rack itself?
Porthos06
Greg
Ontario CA
2023 OBX
Im in the process of having the 4 door rack with support installed. There was a delay due to a couple of wrong parts for other installs. I'll provide pics when its all done.
Cbgarrett
Bronco badlands
Not sure what you mean by tilted.
RC Bronco
Rob
Kansas
If you look at the lines between the mid panel and the front panels, the middle panel is tilted slightly upwards, this causes the roof lines to not match up. It’s particularly evident if you follow the line above the windows from left to right
this has been noticed in pretty much every full length RCI rack install on 4 door Broncos. Some folks have it so bad that the roof sags and in some cases even touches the rear roll bar area
just a question for curiosity sake
dmarked00
Carl
2022 4 Door
It’s my opinion that because the Bronco hard top is a four piece top, any rack, especially a full rack has the potential to cause alignment issues between the panels. I also have the RCI rack, it was installed before the support bracket was available and I haven’t removed it yet just to install it. While I have some flex in the rearmost section, it’s not as bad as I’ve seen on other hardtops. ✌🏼
RC Bronco
Rob
Kansas
I appreciate that and think I recognize your sentiment from another post
Thank you sir
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Do you have the front fairing installed? Can you post a pic? I’ve been thinking of ordering one for when I don’t need the full rack.
Cbgarrett
Bronco badlands
I doubt I ever would have noticed that! I didn't notice anything before. I did just install the little support piece this afternoon
