Rear Parking Sensor Connections
friethmiller
Everglades
Fred
Austin, TX
2013 F-150, 1974 Porsche 914, 1974 Porsche 914 LE
Everglades
Looking for some help on this one. I removed my rear bumper to replace the top plastic trim cap a few weeks ago and I can't get the rear parking sensor connections back together. A teenager backed out of a parking spot next to mine and clipped my rear fender's end cap. When their car pulled the end cap off it also ripped some of the plastic connectors on the top plastic trim on the bumper. So I had to replace both items. After replacing the cap and top plastic trim piece (both FoMoCo parts), I was unable to reconnect the backup sensor wire connectors. As much as I tried, the two connectors just won't snap together, on either end. Either something broke or I'm doing it all wrong! Hoping it's the later. Has anyone else ever had this problem and figured out? Thanks in advance.
Before / After pics
1 or the 2 connections.
Ford Bronco Rear Parking Sensor Connections IMG_3705
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
Use a dielectric grease on the seal especially. These connectors are a PAIN without it.
Also, make sure there are no grains of sand/dirt or tiny pebbles in there… mother nature finds a way
friethmiller
friethmiller
Everglades
Fred
Austin, TX
Everglades
Ok, that worked! Those connectors are a real PIA!
friethmiller
friethmiller
Everglades
Fred
Austin, TX
Everglades
Thank you!!
Bellime
Keith
2022 Ford Bronco
Good reminder to put a little of that specific type of lube anytime opening these connections. Saves headaches later
friethmiller
friethmiller
Everglades
Fred
Austin, TX
Everglades
Yes, I agree!
englishdave
Arizona, USA
2025 Bronco
Cross posting from the a related thread, I had the same issue. Installed the Factory Tow Hitch package on my 2025 Bronco Badlands and the bumper connects would not latch together.
Went down to the auto parts store and taking the the additional advice in the forum due to working with electrical connectors, purchased a two part solution:
WD-40 Contact Cleaner (for electrical parts, quick drying, no residue), cleaned both sides of the connectors with a generous squirt, let dry for 30 seconds.
CRC dielectric grease, a good amount applied into the bumper side connector.
Pushed them together, and they connected without issue. Problem solved, no more errors, sensors alert appropriately, and the license plate is illuminated.
