Does anyone know if you can remotely lock the bronco while it’s running with the keyfob? I’m going to be ordering a base squatch so it won’t have the proximity keyless entry
my 2020 Tacoma won’t and its a huge annoyance. The work around is I have to roll down the window, get out, manually lock it using the interior lock switch, roll up the window using auto-up. Then I have to use the physical key to open the door to get back in. Super annoying when it’s 120 degrees to not be able to precool the vehicle with it locked
