Remove grill , disconnect fluid lines ?
Jeverall
James
Tampa fl
Jeep Grand Cherokee
Hello, trying to tackle grill removal to change the white “BRONCO” letters on my outer banks…
Videos online I found only show removal of clips and screws… but there appears to be 2 lines running from the engine bay that are secured to the grill, preventing removal .
Any guidance on disconnecting ??
Ford Bronco Remove grill , disconnect fluid lines ? C230CD7B-A1AA-43E2-A61E-DA2CEACFCBAE
Ford Bronco Remove grill , disconnect fluid lines ? 41764F4C-2C41-4D0F-8DD1-D978B5DA8809
VelocityBronco
E
One is for the camera, the other for the camera sprayer tube. Those are quick disconnects in your pictures, just squeeze the connectors and pull them apart. They have clips that hold them together that need to be pushed in.
SubmarineNuke
Richard
Houston, TX
twitch.tv
Bronco Wildtrak
the brown one is the front facing camera, and the black one is the washer fluid for the camera.
Both come off with a little squeeze and some effort.
I know you're not doing this mod, but this video shows and talks about how to do it.
Ground_zero298
Scs michigan
It’s okay to unhook those!
Jeverall
Jeverall
James
Tampa fl
Jeep Grand Cherokee
AWESOME- THANK YOU!!!!!!!!!!!!!!!!
BroncoSarge
Jeffrey
Fort Bragg, North Carolina
It’s fine to unhook them. Took my grill off to paint to match the bumper.
Ford Bronco Remove grill , disconnect fluid lines ? C34CFDC1-2830-45A4-AFD6-0C8163FDF96F
Jeverall
Jeverall
James
Tampa fl
Jeep Grand Cherokee
Thank you! I got mine off. I just drilled the white letters out , I haven’t replaced them yet …. But kind of like the look of the all gloss black …. Even with the holes in the letters
Ford Bronco Remove grill , disconnect fluid lines ? 47CC888A-2445-4C1B-8299-259229A401E7
