Replacement Torx screws
Dmorty217
Derek
Venice FL
Camery
Anyone know where to get black Torx screws, specifically the smaller of the two that go on the mirror hardware mounts? Somehow one of mine is slightly larger than the other in the Torx head and I want to replace it.
ā€˜21OBX
90Bronco19
2022 bronco outer banks
The outer ones I want to say are a smaller head that they don’t give you in the kit. I ran into this when I installed my ditch lights. Annoying as F if you ask me. Why they are not the same size that they include is behind me.
Dmorty217
Dmorty217
Derek
Venice FL
Camery
I just installed my ditch lights and wasn’t able to get one of the two back in completely, sounds like we both had the same issue. I stopped trying to tighten it down so not possibly ruin the threads in the stud. Just going to buy another screw and try again. I saw some on eBay but they aren’t black. My dealership is open but parts isn’t so I have to wait until Monday I guess.
ā€˜21OBX
90Bronco19
Wait your threads are smaller? Mine just the ford head was smaller and they are forever long. Mine tightened fine just found it odd they have two different head sizes.
DaveInSA
Seguin, Texas
2025 F150 Lightning Flash
The smaller one is a T25. Do NOT believe it's a Torx Plus, just regular torx.
Just had to buy a new tool for it myself.
mike8675309
Minnesota
Dmorty217
Dmorty217
Derek
Venice FL
Camery
No threads aren’t smaller but apparently I had the wrong Torx bit that caused my issue.
Dmorty217
Dmorty217
Derek
Venice FL
Camery
mike8675309
Minnesota
Great resource but I’m clearly not that smart so how do I find the correct screw?
Open the page and look at the left. Tell it the thread size, and the length you are looking for along with the drive size. If you don't know those, take one of yours to the local hardware store and ask them to identify the thread size for you. You can measure the length. Once you get that far you can even specify the head diameter and the type of head you want.
Its Brawnco
Maryland
2011 F150 Raptor, 1978 F100, 2016 Ducati Scrambler
Both of the mirror/a-pillar bronco bolts are the same thread pattern and the longer one will fit in both of the holes. (either of the bolts will fit in the others hole). I lost one of my bolts so I went down to Ace Hardware and was able to match it up to an allen key head bolt that fit perfectly.
