SiriusXM Cutting Out
North7
North Texas
SUV
Probably doesn’t help I have a GOBI rack too. Now I’m wondering once I add the RTT if it will just knock it out completely.
Ah, the truth comes out, any metal over or around the antenna will block the signal.
The RTT not so much since it is made out of non-conductive fabric. However, bed slats / boards and mattresses will not help as you add up the thickness, it will start to attenuate the signal.
What you need is an antenna relocation kit, move it to the top of the rear third brake light or something like that. Here is one for the Ford F-Series trucks and a couple for Jeeps.
Any way to relocate Sirius satellite puck?
JK wrangler Satellite Antenna Relocation Bracket
Maximus-3 JL SATELLITE ANTENNA RELOCATION BRACKET-jl-satellite-antenna-relocation-bracket
With the Jeep ones you still have to research extending the wiring (antenna coax, etc), you need an extension harnesses kit for that as you don't want to extend shielded wire unless you really know what your doing. Maybe Maximus has them available for the Jeep kits, you could call them or google and see if they or someone else will make them for the Bronco, seems likely.
GrumpyVet
GrumpyVet
Joel
Finished the fix as mentioned in the TSB and noticed a significant improvement. There’s no need to remove the top just remove the rear header trim panel to access the bolt holding the antenna cut the plastic tab with a razor knife and reinstall rotating the antenna 180deg from original orientation.
Geo
Geo
Ford Mustang
My 2 door has the same issue. Are you all 4 door owners?
GrumpyVet
GrumpyVet
Joel
Yep 4 doors here. It’s been close to two months since performing the fix and maybe it’s a slight improvement but it’ll still annoyingly cut out until the middle roof panel is removed. With the panel out of the equation satellite radio might be actually enjoyable. Now if only the sound system could be heard over the wind noise. The good news is the wind does overpower the sound of children. So I got that going for me.
RHeinz
Ric
Houston, TX
So…a bunch of them were simply installed backwards….
Geo
Geo
Ford Mustang
One of the first things I did was upgrade the sound system. Stinger base on rear door, amp, new speakers all the way around. Volume is not my issue. I've also had the rear top off since May. I just wish XM was reliable.
GrumpyVet
GrumpyVet
Joel
Not exactly. The fix puts them backwards from originally designed location. It’s Ford’s attempt to resolve the issue of a poor design. My guess is a true fix would require a complete relocation of the antenna or adding additional antennas.
RHeinz
Ric
Houston, TX
My read was that you can tell if its properly oriented by looking at it from the top. Something about the edges lining up with the sheet metal covering the roll cage.
GrumpyVet
GrumpyVet
Joel
The antenna sits indented in the sheet metal. So yes, if the antenna is properly aligned in the sheet metal and you are experiencing the issue you can rotate the antenna 180deg so it is no longer correctly aligned within the sheet metal. If it’s already installed backwards then I think in step 2, they tell you to stop as the fix will not pertain to you.
MrParticular
New York
davidlauterbach.com
2022 2.7 Bronco, 1989 5.0 25th Anniversary Mustang
I read that Ford PDF. Looks like mine is backwards too... posting pics for anyone who wants to see... or someone tell me if it's installed properly. But it looks "correct" to me, which according to the doc, is wrong.
2022 4 door
Ford Bronco SiriusXM Cutting Out BroncoAntenna1
Ford Bronco SiriusXM Cutting Out BroncoAntenna2
sportcoupe
Georgia
2023 Bronco
My 2023 four door hard top has poor reception at times. Check the antenna position and it is installed "backwards", which is correct per the 2022 TSB.
Relocating antenna to the top of the rear brake light seems like a lot of work to run the coax if such a long coax extension was available.
Not sure where we could relocate it to though with a removeable hard top.
