Skid plate for rear lower trailing control arm
Victorsen
Victorsen
Vic
Maryland
Ford bronco
Thanks when will that be available
AdamF@IAG
Adam
Maryland
iagoffroad.com
'22 Bronco Raptor, '21 Bronco 2 and 4 door, '24 Ranger Raptor
We should have these released in the next 2 weeks or so. Should start seeing them on the website shortly.
TTT
Alberto
Baja
Mustang Mach E Premium
nice ! exactly what i needed
GroovyGeek
Boyan
'23 Bronco BD
Can you post here when they are available? I don't see them on the website yet.
AdamF@IAG
Adam
Maryland
iagoffroad.com
We are currently welding the skid plate offerings, so it's really close. We ran into some utilities hurdles getting the new powder line up 100%. It's all coming, hopefully by the end of the year!
GroovyGeek
Boyan
'23 Bronco BD
It's kind of a shame that most of these LCA skids require futzing with the gas tank to install on the passenger side. As far as I know only @ASFIR 4x4 has LCA skids that do not require that, but they don't fit over the BL/BD LCAs. This one also requires more drilling than others. I am hoping that the @IAG Performance one will be less involved, though it is guaranteed to be more expensive than the DV8 one.
Victorsen
Victorsen
Vic
Maryland
Ford bronco
It's kind of a shame that most of these LCA skids require futzing with the gas tank to install on the driver's side. As far as I know only @ASFIR 4x4 has LCA skids that do not require that, but they don't fit over the BL/BD LCAs. This one also requires more drilling than others. I am hoping that the @IAG Performance one will be less involved, though it is guaranteed to be more expensive than the DV8 one.
Wow that is a great price for those skids
AdamF@IAG
Adam
Maryland
iagoffroad.com
Ours will not require messing with the fuel tank. The only part of the install that is tricky is on the passenger side. There is a plate that protects the tank from the RTA bolt, but our skid is designed to fit around it. Other than that, 3 bolts on each side and can be done with the Bronco sitting on the ground.
Big Boss
Outer Heaven
Bronco Big Bend
oooo IAG is going to be making skid plates. Consider me intrigued, love all the stuff I have gotten from them so far.
IAG Off-Road
JJ
Westminster, MD
www.iagperformance.com
GroovyGeek
Boyan
'23 Bronco BD
We just added most of them to the website with a "Notify when available" button!
https://iagoffroad.com/search/?brand_name/IAG-Performance&query=skid-plate
Fantastic. I see a bit of artistic license in the description :D but that's OK
"The IAG Rock Armor Front Lower Trailing Arm Skid Plates are also the first on the market for compatibility with the Bronco Badlands and Black Diamond factory skid plates."
Looking forward to the install instructions and/or video.
Oldhippie
Barry
Santa Cruz, Calif.
I have a set of new JCR skids if anyone is interested…decided to just go with the stock ones already on there…as long as they last…
Deano Bronc
Dean
Winona Lake, IN
2022 Badlands
Love the Foutz design on their skids but had a friend try to install them and had all kinds of issues. He ended up taking his Bronco to Foutz to have them installed.
I ordered a set of IAG skids since they fit the Badlands with the factory bracing and they seem really easy to install. I'm also going to order a couple of sheets of HDPE to bolt on so they are similar to the Foutz design.
