Stereo Volume Issue
Hitman
Tony
Wellington, FL
2011 Explorer, 2016 Fusion, 2019 F150 Lariat 4x4
Well, three weeks to the day after taking delivery of our four door OB, the volume on our bronco audio decided to stop working. The audio volume is stuck at zero! Can’t raise it either with the knob or with the steering wheel controls. There is no mute to be found like on the steering wheel of my F150. Anyone know of a fix or what we are missing??? I have a feeling it’s something major bc it’s not allowing me to change other settings for audio. Thinking about disconnecting the negative battery terminal and hopefully getting a reset to fix the issue. Let me know if you have any ideas…. Btw, it’s the 12” screen w the B&O and the Lux package…. Thx
Roll Sound
Hollywood
2021 Wildtrack 2DR MIC OW, 2014 KTM RC8R
That's what I'd try first. Do batt and report back.
Bronco cat
Carl
Morgantown wv
‘20 Explorer ST, ‘19 GT350, ‘21 Bronco Sport
Yes. That’s software related most likely. Battery disconnect should cure it
wrbix
VA and FL
LR Def90, F250 7.3, Caterham 7, LR Series III, etc
Mute on?
Ford Bronco Stereo Volume Issue F9C3D7EE-D0E8-41DB-9A97-FA36434D0B99
Contact
Randy
Austin, Texas
Bronco Big Bend. FJ Cruiser
push the volume button
TwinTurboStang
CT
Brodiak
Disconnect both pos and neg and touch the wires together (not touching the battery) and hold for 30 sec. Then reconnect
Hitman
Tony
Wellington, FL
Thank you all for ur input!
After disconnecting the negative battery terminal for about two minutes and reconnecting, radio is back to normal, for now at least…. Have a great day and happy thanksgiving!
talbrecht
Tim
NY, NJ, PA
4Runner, Wrangler, FJ40, LR4, Sequioa
I have 2022 Badlands Lux, volume stuck at zero and on/off on the stereo doesn’t work. Did the battery disconnect and still no volume. Heading to dealership.
80H-d
Scottsdale
22 WT Lux
I think I have this same issue. Thought it was something messed up with SYNC for the longest time. FM, bluetooth, AA, sirius, no audio source makes sound. Fuse is good. Guess it's the dealership for me too. They timed it really well, as my warranty just ran out a couple months ago :)
