Tailgate Table recommendations!!!
KlynB95
KlynB95
Kailynne
2024 Bronco
I'll second the Trailgater. I bought this after watching your review. I ordered an extra plastic cutting board that stows inside the table when closed but provides 2 side extensions when open.
Does it make any noise when it’s closed? That’s my biggest concern. I already have a tent that I’m trying to track down a squeak from! Haha
KlynB95
KlynB95
Kailynne
2024 Bronco
Thank you all for your recommendations! I really appreciate it!
CoolContractor
Fred
Absolutely zero rattles. Buy once, cry once.
Ninjak
Miami
I love this one too!! Does it make any noise when closed??
There are zero rattles. It is secured by latches, has bump stops in the table, and uses foam striping behind it on the tailgate. I was impressed with how well thought out and simple it was.
Also, it's sturdy. Very sturdy. When in the unfolded position, it is solid. I like having the ability to also expand the table.
FastTimesFord
United States, CA, Whittier
Ford Bronco
My Rough Country works great and it's simple. Bought it a few years ago for my Jeep. It was under $100 and ZERO rattles. Got it from Extreme Terrain.
When the table is folded up there's plenty of spots to mount molle bags. Basically, a functional table in both positions.
I'm working on a custom removable wood top. It will mount over the molle straps using the pre-drilled holes.
Ford Bronco Tailgate Table recommendations!!! IMG_5244
Ford Bronco Tailgate Table recommendations!!! IMG_5243
mjcutri
M
Lisbon, Portugal / Pittsburgh, PA
2023 Bronco HE
I just installed the Front Runner Tailgate Table.
I took advantage of the memorial day sale to pick it up for 20% off.
The only negatives I have so far is that the Bronco specific cutting board (shaped to fit around the tailgate bump) isn't as nice as the standard cutting board (which is butcher block wood and is also included with the Bronco kit) and it uses jack nuts that are a pain to get tight, but I couldn't justify spending almost 2x for the Trailgator just to avoid drilling a couple holes.
I may end up replacing the included board with a piece of butcher block cut to match the included piece.
CoolContractor
Fred
The only negatives I have so far is that the Bronco specific cutting board (shaped to fit around the tailgate bump) isn't as nice as the standard cutting board (which is butcher block wood and is also included with the Bronco kit) and it uses jack nuts that are a pain to get tight, but I couldn't justify spending almost 2x for the Trailgator just to avoid drill a couple holes.
Looks very nice. I opted for the Trailgater. They all accomplish the same thing. Buy what works best for you. No rattles was the top priority for me, then function. I got both and am very happy.
The Beaz
Shad
San Francisco
I went with the Hooke Road Table/storage box....love it! Definitely use the storage, esp. when the top and doors are off.
Ford Bronco Tailgate Table recommendations!!! PXL_20230821_005018521
mjcutri
M
2023 Bronco HE
Ended up replacing the stock board with a $30 black HDPE cutting board that I trimmed to match the original. I think it turned out pretty good and looks a lot better. Absolutely no rattles.
Ford Bronco Tailgate Table recommendations!!! PXL_20250703_151450307
Ford Bronco Tailgate Table recommendations!!! PXL_20250703_151507896
