TPMS Issues on New Wheels
Retired Guy
2019 Honda CRV
I just swapped a brand new set of takeoffs from a 2024 Badlands on my 2025 Big Bend. The takeoffs had TPMS sensors installed so I just bolted on the new tires and wheels. After 15miles or so, the TPMS fault light came on and the tire pressue monitor light remains on the dash. Do the sensors need to be programmed for my car? Is this something I can do or do I need to go to the dealer.
Baja Bronco
2Sun AZ
22 Ford Bronco, 20 Ford Raptor
I know from Discount Tire installing the TPMS on my off road wheels, there are 2 hrtz frequencies. The TPMS in the wheels probably have the different frequencies. Sucks, but you’ll probably need to buy 5 new ones, including the spare if you got 5. If you have a Discount Tire by you, they can do it no problem.
anomdeplume
Tampa, Florida
2023 Bronco Base, 2023 Bronco Sport Badlands
I bought a set of OBX takeoffs once and was told the TPMS were included. They were not. I had the same issue that you have as soon as I installed them. Buyer beware. Had to get new sensors installed.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Did you ever figure this out? I’ve had a backup set of steelies and new sensors laying around until my Toyo AT3s were spent…turns out I’ll be a proud unexpected owner of a 2025 (my 21 was totaled) starting next week and this certainly would complicate things. Word is that the 2025s require a new part number for the sensors.
GnormalGnome
ee
PNW
2025 Ford Bronco
The MHz frequency that the TPMS use changed for MY25.
You will need to replace the sensors with new ones at the correct frequency.
Bschurr
NY
^ THIS
redone17
Cold Spring, NY
Ugh. I was afraid of that.
Part number?
74broncosport
scott
clarinda
24 badlands 22 willdtrak
When we bought new wheels and tires for our 24 the company sent the 433 mh Tpms. Ther sent a tool thar connected to the computer and were able to sync them. After syncing we used to cheap tool on Amazon to activate sensor during the tpms learning process.
redone17
Cold Spring, NY
SKU: M1180D
Blue Oval Industries has the best deal.
