Wheel hub rust!?
Qarlos
Caleb
Doha, Qatar
2022 Bronco Wildtrak
Hi gang,
I rotated my tires at 5k miles and the surface rust on all 4 wheel hubs surprised me. I've had foreign makes previously and never saw this even after 100k miles. Just looking for some feedback that this is normal, expected, or WTH?
Thanks!
Ford Bronco Wheel hub rust!? IMG_3612
Qarlos
Qarlos
Caleb
Doha, Qatar
Qarlos
Qarlos
Caleb
Doha, Qatar
Funny, I searched for this topic and didn't turn up any results. However, down below in "similar threads" I now see:
Rusted Hubs(?)
Sorry for the dupe.
lapazleo
2022 bronco badlands
I've never owned a vehicle that didn't do that even the 3 years I lived in Florida. Pretty much normal.
Qarlos
Qarlos
Caleb
Doha, Qatar
Rusted Hubs(?)
Sorry for the dupe.
Well that thread wasn't much help, LOL.
Anyway, yes, surface rust. Agreed. Just hadn't seen it on my other cars.
TRACKTOY
ANDRÉ
ST-AUGUSTIN-DE-DESMAURES Qc. CANADA
F150 LARIAT CREW C. 3.5L ÉCO 2022+ BRONCO BL.2023
ITS`S NOT FORD
ALL COMPAGNY IT'S THE SAME When you change your disk you can buy COATED no rust for 3 year. question IT'S your first car in your life?
TRACKTOY
huey
kevin
Ontario & Kentucky
every vehicle I have had has done this
Ford, GM, Dodge, VW...all of em
St Paul
Land Rover
That’s nothin! I’ve got a Land Rover Discovery 2. It has Lug bolts and the bolts have sort of a decorative sheet steel (stainless?) cover on the bolt head.
Had a flat out on a trail and when I went to remove the spare off the rear door mount, for the first time ever btw, one of the bolt heads inside the cover must have rusted just enough to cause the cover to bulge and prevented the lug wrench from fitting over it. That was not a good day!
Mjasi3
Chicago
wjtinfwb
Destin FL
Jeep GC, Excursion, Focus ST, Subaru Crosstrek
Hi gang,
Thanks!
I’ve not had the wheels off my Bronc yet but that’s pretty normal for all makes. It’s unpainted cast iron which rusts when you breathe on it, that and the corrosion that naturally occurs from the aluminum wheel tight against the cast iron rotor cause the surface rust. I would not worry about it but if you wanted to you could clean the hub with a wire brush then paint the hub to try and prevent it in the future.
SoDak1623
Cole
South Dakota
1996 F150, 2022 Badlands MT
An unpainted part that goes through constant heat cycles and it has surface rust? The horror...
