Where does this go (kicker key'200.4)
BroncoBerry
BroncoBerry
Berry
United Steaks
Sorry, I mean the blue connection. Is that a ground?
HighVelocity
Big Sky Country
Pinto
Annnnd this is why I don't buy used vehicles anymore.
In a 12v system, a black cable 'typically' denotes a ground connection. It's best to refer to documentation of the device to check for certain, or test it yourself.
Ninjak
Miami
By the way that is set, it looks to be a ground. By gauge and connector.
But yes, give it a test.
Brutal-Force
2023 Ford Bronco
Its the ground for the plug n play kits. Do yourself a favor before you put it on a bolt to ground and check that the crimp is snug. Mine came out.
M_Burdge
St Louis City
2023 Bronco
Yep. That's the ground. I'm curious where/how you have (or are going to) routed the power feed to the terminal in the engine compartment.
I just got the current kit from PlugNPlay and will be installing it soon.
BroncoBerry
BroncoBerry
Berry
United Steaks
The power was routed from the glove box area through the center console area to a plug in the firewall. If you look too left in the driver's side you'll see the knock out grommet to the firewall. I cut a small hole through the knock out grommet using a razor knife.
Ford Bronco Where does this go (kicker key'200.4) PXL_20230819_213333927
Ford Bronco Where does this go (kicker key'200.4) PXL_20230819_213255261
M_Burdge
St Louis City
2023 Bronco
Thanks. Also curious about how you finish mounted the amp on the passenger side.
BroncoBerry
BroncoBerry
Berry
United Steaks
BroncoBerry
BroncoBerry
Berry
United Steaks
A couple tips
I realized I could have routed the wires through the center console and between an ac duct instead of under the glove box (photo with my hand)
It helped to route my amp wires over the black bracket in the glove box.
when you're putting the amp in to the slot, lay on your back and push one side up through first
Really, a clean install if you do it right .
Ford Bronco Where does this go (kicker key'200.4) PXL_20230820_163248189
Ford Bronco Where does this go (kicker key'200.4) PXL_20230820_163330742
Ford Bronco Where does this go (kicker key'200.4) PXL_20230820_163905828
Ford Bronco Where does this go (kicker key'200.4) PXL_20230820_164036268
M_Burdge
St Louis City
2023 Bronco
A couple tips
I couldn't use that big grommet - that's where my clutch passes through the firewall 🤷‍♀️. I had to use the smaller one further up and to the left of the clutch pedal mechanism.
Eharris55
Elgeo
Washington, DC
N/A
A couple tips
Where did you end up putting the ground wire behind the glove box?
