Where is everyone getting 12v for an LC2i or higher?
Axiom89
South Dakota
2022 Ford Bronco Base
Where is everyone getting 12v for an LC2i or higher? Can we just tap the 12v plug in the back or everyone using a add a fuse? If using the add a fuse which fuse are you using?
DJ1
Minnesota
2022 Honda Civic Si, 2020 Toyota Tundra TRD Pro
Not using the LC2i in my Bronco, but here is how I set it up in my Civic Si. Power distribution block to split the 12V coming direct from the battery. LC2i triggers the amp remote turn on through GTO.
Ford Bronco Where is everyone getting 12v for an LC2i or higher? amp1
Axiom89
South Dakota
Where did you get that distro?
rtazz17
Rob
Connecticut
2022 Ford bronco big bend
clean power direct from battery
