do you have a VIN?I get an invalid order number....smh
Yesdo you have a VIN?
are you using the order code from your build sheet?
Reservation number which was the number used successfully in back door link. Should I be using the other?are you using the order code from your build sheet?
If you have a VIN you have to use the order code from your build sheet with the VIN. it is 3 numbers and 1 letter on mine.Reservation number which was the number used successfully in back door link. Should I be using the other?
Oh cool!! Thank you!! I guess I'll go out in the cold and dig it up.....If you have a VIN you have to use the order code from your build sheet with the VIN. it is 3 numbers and 1 letter on mine.
Hey!! It works!! Thank you much. The thought crossed my mind but I was just being lazyIf you have a VIN you have to use the order code from your build sheet with the VIN. it is 3 numbers and 1 letter on mine.
