- Jul 21, 2020
- 3
- 50
- 116
- Saudi Arabia
- Infiniti G37
- Badlands
When we look at the amazing crawl ratio of nearly 95:1 found on the Badlands (w/ manual), we understand that it mainly comes from the high ratio of its crawler gear (6.6) and the large axel ratio which is (4.7). However, the automatic transmission which doesn't have a crawler gear relies on its 1st gear that has ratio of (4.7). It produces a crawl ratio of 68:1 and that is less than what the Rubicon offers which is 77:1. The reason why the automatic Rubicon has higher crawl ratio is due to its larger low range ratio which is (4.0) compare to Bronco's (3.06). Below explains how the crawl ratios were calculated:
Bronco Badlands (Manual) = Crawler Gear (6.6) x Axel Ratio (4.7) x Low Range Ratio (3.06) = 95
Wrangler Rubicon (Manual)= First Gear (5.13) x Axel Ratio (4.1) x Low Range Ratio (4.0) = 84
Bronco Badlands (Auto) = First Gear (4.71) x Axel Ratio (4.7) x Low Range Ratio (3.06) = 68
Wrangler Rubicon (Auto) = First Gear (4.71) x Axel Ratio (4.1) x Low Range Ratio (4.0) = 77
I was wondering to know why Ford didn't use a larger ratio for the low range of the transfer case. That might not help much the manual transmission because it already has an amazing crawl ratio, but it would help the automatic Broncos. If a 4.0 ratio is used, the crawl ratio would be 88 instead of 68 which is higher than 77 of the Rubicon's!
Any thought?
Any thought?
