Winch w/ mount on B&P
BroncoSarge
Jeffrey
Fort Bragg, North Carolina
is the winch mount removable? Is there a wiring disconnect for the Winch?
Thed
Ben
Raleigh, NC
'22 GX460 '16 Miata '67 F-100 '21 Streetfighter V4
Yes and yes, but probably not as easily as you're wanting.
john houseman
Marlow, OK
2013 F-150, 2000 F-250, 1969 Cougar Convertible
Does anyone know which bull bar/safari bar will actually come with the winch kit? B & P shows both a low and out front bar, and a high bar that is front of grill "BRONCO" lettering. I like the low and out front, but not the higher one.
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
it looks like it's a fairly permanent installation.
it would be great if a front hitch mount was available if you wanted to pursue a removable hitch.
would also have to beef up the rear hitch mount to something sturdier than class ii to use the winch to pull backwards instead of forward.
SafariJeff
Lake Tahoe, Nevada
1994 Defender / 2020 Rubicon / 2023 Wildtrak
Going WT for the disposable front bumper and will have to go aftermarket (not found one yet but it is a matter time) for a front bumper with a receiver hitch to attach the winch only when need and playing in the desert. Hate carrying the winch 24/7 and 50% of the time you get into trouble you need to winch backward with in help with it mount on the front.
Ford Bronco Winch w/ mount on B&P Winch reciever plat
Ford Bronco Winch w/ mount on B&P Winch reciever bumper
Ford Bronco Winch w/ mount on B&P Winch on Bumper
Ford Bronco Winch w/ mount on B&P Winch on reciever
BroncoSarge
BroncoSarge
Jeffrey
I’m hoping someone will have a shot of the two attaching points. Looks like they can be changed from hooks to winch to rings. I’m hoping that part is how it comes off with two hitch pins. If that is the case, I can even work out a power/relay switch and disconnect. I want to remove it for daily driving and attach for off-road weekends etc.
BroncoSarge
BroncoSarge
Jeffrey
Basically make those two holes fit a standard 2” hitch.
Ford Bronco Winch w/ mount on B&P B7962FCD-3945-45B3-B5F2-894FDF528C9B
