Window water spots.
Watzupdogs
Randy
Oklahoma
Ram 1500 4x4
Anyone else having issues with water spots that wont ho away on there windows.
I use a water filter on my hose when i wash the bronco and use chemical guys soap that is supposed to help with water spots and i apply the,soap via a power sprayer.
I then wiped it it dry.
And my windows still have water spots.
Ive used 3 different brands of window cleaner and nothing helps.
What the heck.
Any suggestions
Santos
Santo
Lenoir City, Tn
1977F100:1970 Mustang Fastback
You can try a Mr clean sponge to get the spots off, I use isopropyl alcohol and distilled water to clean glass with 50/50 mix.
Sandbergo
Jelani & Dave
Orlando
Rogue
Chemical Guys also has a water spot remover, you likely have minerals in the water that are causing them.
Blaven
Pennsylvania
Try a clay bar. They work wonders on windshields.
Lifeliberty
Moonbeam👀
Columbus, OH
White vinegar for dissolving water spots caused by hard water.
Spray on, wipe dry
Watzupdogs
Watzupdogs
Randy
Oklahoma
Ram 1500 4x4
I have a water filter on my waterhose that takes out hard minerals and metals.
I dont have this problem on any other vehicle. Tomorrow ill use a clay bar on the windows and add a little polish and see if that helps.
