Wolfbox connections
M_Burdge
St Louis City
2023 Bronco
Anyone have the Wolfbox 900 series installed with the park feature? I'm looking for alternatives to the fuses selected in their instructional video as the add-a-fuse they put in the #3 position fuse in the interior fuse box doesn't quite fit. The wire extending out to the right gets interference from the fuse box wall.
Suggestions?
jayr1959
Jay
Delaware
2015 Jeep JK 2DR 2008 Saturn Sky Redline
I used the OBD power adapters which worked fine but it was so sensitive it would turn on all the time and drain the battery..
BroncoA512021
Long Island, NY
www.facebook.com
2021 Ford Bronco OBX
Suggestions?
I retuned it. When I attached to the fuses exactly as instructed in their video, it affected my parking sensors...
M_Burdge
M_Burdge
St Louis City
2023 Bronco
Their instructions and video leave alot to be desired.
JerryC
Memphis
2022 Bronco
I'm looking at this mostly as a rear view mirror replacement. How well does it work for that?
sabasigh
STL
2024 Bronco
JerryC
Memphis
2022 Bronco
sabasigh
STL
2024 Bronco
Thanks, there's no way to mount the camera to the rear glass like most dash cams?
My back glass is tinted 5% so i had to mount on the outside of vehicle
JerryC
Memphis
2022 Bronco
I put the Wolfbox 900 on the Raptor yesterday. In the daytime the front camera image looks great, the back camera image looks good.
At night front camera image looks good and the back is not good. The image from the back camera looks really grainy. It's usable and overall better than a mirror.
It's so nice to look in the mirror and see what's behind the vehicle instead of two headrests, a spare tire and a third brake light.
I did rig the bracket so I could mount it inside to the back window and the little bit of factory tint has to be hurting the effectiveness of the camera at night. The benefit is that there almost no camera shake.
The mirror blocks the driver side visor from flipping forward. Not an issue for me but others may want to know that.
‘21OBX
Ken
90Bronco19
2022 bronco outer banks
I think I had to flip one of the fuse taps to face down so it sat correctly. If you have a test light use it to find a fuse that comes off/on with the key and one that stays on all the time.
