- Mitch
- Apr 7, 2021
- 91
- 291
- 998
- St. Louis, MO
- Website
- www.pandamotorworks.com
- 2021 Ford Bronco, 2014 Fiesta ST
- Outer Banks
Zone Offroad, a leader in high-performance Lift Kits, Leveling Kits and suspension products, is proud to introduce solutions for the all-new Ford Bronco. Designed right from the factory to accommodate large tires and custom offset wheels, the Bronco platform is easy to modify. For some applications, a 1" leveling kit may be all that is needed to improve safety through increased tire-to-frame clearance. Zone Offroad's high-quality affordable solutions are perfect for enthusiasts who prefer to spec out their own upgrades. Higher lift and complete coilover suspension lifts are in development.
We are happy to announce that we are now offering both the 1" Level and 2" lift kits by Zone Offroad for the Bronco! We have a large stocking order on the way of both kits, and we expect to start shipping them out come early August! If you are in the market for a lift kit or leveling kit at a great price, check out Zone Offroad on pandamotorworks.com!
1" Leveling Kit
Right out of the gate the 2021 Ford Bronco is an impressive machine offering cool retro styling and off-road pedigree that rivals anything on the road these days. Available with the standard IFS suspension or upgraded Sasquatch package providing 1.1" taller ride height, the Bronco has clearance for up to 35" tires from the factory. Building on the 4-corner coilover design Zone Offroad offers a 1" leveling kit designed to level out the stance and eliminate the factory nose-low rake. This improves the appearance with clearance for larger aftermarket wheel/tire packages without sacrificing vehicle drivability. The leveling kit uses a 2-piece design with upper and lower strut mount spacers that install easily to provide the desired level stance on all Bronco models. These spacers are built from high-strength American steel laser cut for a precision fit and finished in a durable black e-coating. These paired with the longer replacement hardware and step-by-step instructions allow you to bolt-on this 1" leveling kit within a few hours.
Front Lift Height | 1" |
Material | Steel |
Front Lift Method | Strut Spacers |
Lift Type | Leveling Kit |
Wheel Size | 20 x 9 |
Back Spacing | 5"-6" |
Max Tire Size | 35" x 11.2" |
Wheel Size 2 | 20 x 9 |
Back Spacing 2 | 5-5.5" |
Max Tire Size 2 | 35 x 12.5 |
Is Adjustable | No |
Finish | e-Coat |
Metal Cutting Required | No |
Welding Required | No |
FEATURES
- Levels stance without affecting ride quality or drive-ability
- Allows clearance for aftermarket wheel/tire packages
- 2-piece design for simple bolt-on installation (2 piece design is used so that the top spacer does not require cutting or disassembly of the strut). When the top spacer height is optimized around the simplicity of not cutting or rotating of the top hat then a lower spacer is used to net the rest of the lift needed to get to a level stance.
- No cutting required
- Does not require strut disassembly or rotating the top strut hat
Building off the impressive design and capability of the new 2021 Ford Bronco with its on the 4-corner coilover design, the team at Zone Offroad are offering a 2" lift solution designed for the base model (non-Sasquatch equipped) Broncos. These new 2" lift kits are lift and level the stance eliminating the factory nose-low rake and allowing clearance for up to 35" tires. This new kit is designed to take advantage of the impressive travel on the new Bronco utilizing top mounted strut spacers to raise the stance without sacrificing ride quality or overall drivability. The spacers are built from heavy duty semi-aromatic glass-fiber reinforced nylon resin design, offering strength and a clean OE appearance once installed. These paired with the longer replacement hardware and step-by-step instructions allow you to bolt-on this 2" lift kit within a few hours. Give your Bronco a boost with Zone Offroad.
Front Lift Height | 2" |
Rear Lift Height | 1" |
Front Lift Method | Coil Spring Spacers |
Lift Type | Suspension |
Back Spacing | 5.5" |
Max Tire Size | 35 x 12.5 |
Back Spacing 2 | Stock |
FEATURES
- Lifts and levels stance without affecting ride quality or drivability
- Allows clearance for larger aftermarket wheel/tire packages
- Top-mount design for simple bolt-on installation
- Does not require strut disassembly (strut must be slightly compressed to rotate the top hat)
- Designed to work within the operating limits of the factory UCA
