- Jul 19, 2020
- 41
- 3,202
- 12,119
- Northwest Arkansas
- Ford Bronco, BMW R1150 GS
- Badlands
"Bronco Tax" Analysis - Is it real? If so, who is charging it, and how much is the premium?
I have read several allegations on the forum by members claiming that some US aftermarket vendors are slapping price premiums onto Bronco products, because they are quick to market, face little competition, and the market will bear it. This so-called price premium is often referred to as a "Bronco Tax".
I tend to disagree with the phrase "slapping price premiums onto Bronco products," because it implies that it was done without careful consideration of direct costs, direct materials, overhead costs, and profit. All companies, regardless of location, want to cover their real labor and overhead costs when pricing products, and it is a fact that labor costs in some countries like China are lower than in the US, and many overhead costs (e.g., healthcare, environmental, regulatory) are also lower in countries like China than in the US.
Nevertheless, the subject of the “Bronco Tax” piqued my curiousity, so I tried to look for an example to test this hypothesis myself.
Just for convenience, since I am already familiar with @JcrOffroad's products, having purchased several myself, I decided to do some comparisons between what they make and sell for Jeeps and what they make and sell for Broncos.
Below are my findings...
1) Aftermarket folding tables
Jeep
JcrOffroad makes a Fold-Down Table for its JCR Adventure Carrier (15.5" x 14.25" = 221 sq. in.), which has only one latch mechanism (one corner only), and does not have an additional MOLLE grid panel on the bottom, making it single-purpose (table only). $229
The Bronco Tailgate Table is clearly wider and a little shorter (27" x 11.75" = 311 sq. in.), but contains 2 latches (one in each top corner) and has an additional MOLLE grid panel on the bottom, making it dual-purpose (table + storage). $299
Comparison
The Bronco Tailgate Table is $70 more expensive (31%) than the Fold-Down Table for the Adventure Carrier, and it provides an additional latch, 41% more steel surface on the table, plus an additional MOLLE grid panel below the table (dual-purpose).
Verdict
No apparent "Bronco Tax". Possibly a bargain, with the added feature-set.
2) Aftermarket console MOLLE panels
Jeep
The JK Center Console MOLLE panel | Jeep Wrangler (07-18) has 13 MOLLE grid attachment holes + holster clip (limited by available space). $98.10 (on sale)
The Bronco Center Console MOLLE panel | 6th Gen (2021+) has 27 MOLLE grid attachment holes + holster clip (limited by available space). $98.10 (on sale)
Comparison
The Bronco panel is almost 2x larger, but the exact same price.
Verdict
No apparent "Bronco Tax". Actually a bargain, at 2x the size for the exact same price.
3) Aftermarket prerunner hoops for front bumpers
OK, this one is a little more complicated, because the offerings for the two brands are quite a bit different, so let’s start with the Bronco first.
The Bronco Prerunner Bolt-On Hoop | 6th Gen (2021+) Steel Bumper has 1 main hoop (tall/narrow) plus 2 side tubes (short/wide), with 4 brackets, 6 welds, and 4 sets of fasteners. $499
Jeep
The Steel Bumper Prerunner Tube | JL Wrangler JT Gladiator is quite a bit simpler, with 1 hoop (tall & narrow), 0 side tubes, 2 brackets, 2 welds, and 2 sets of fasteners. It is also quite a bit cheaper. $219
To account for the difference in designs, you would probably need to factor in some additional components, which JcrOffroad sells as DIY add-ons.
The next photo shows the DIY Jeep Bumper Hoop | 31x14, which is roughly equivalent to the tall/narrow hoop on the Bronco Prerunner, but is bare steel only, with no notches, brackets, welding, powder-coating, or fasteners. $159
The next photo shows the DIY Jeep Bumper Hoop | Prerunner Side Tubes, which are roughly equivalent to the Bronco's Prerunner side tubes, but are bare steel only, with no notches, brackets, welding, powder-coating, or fasteners. $129
Comparison
If you take the two bare steel components above ($159 +$129 = $288) and add 2x the difference between the finished hoop, with 2 welds, 2 brackets, and powder-coating (($219 - $159) x 2 = $120), the adjusted total would be $408... only $91 lower than the Bronco Prerunner, which has 2 additional welds, more notching, and arguably more steel, due to the wider front bumper of the Bronco versus most Jeep models (albeit not quantified in this analysis).
Verdict
No apparent Bronco tax, after adjustments, but you have to do a little math to come to that conclusion, given the differences between the two products.
4) Aftermarket half-doors and tube doors (2-door models)
Jeep
The JK Half Doors | Front | Crusader Trail Doors | Jeep Wrangler (07-18) include steel skins, hinges, and latches, but no tube frame. $1,049
The Bronco Tube Doors | 6th Gen (2021+) for 2-door models include tube doors, hinges, and latches, but no steel skins. $899
Ford Performance
The Ford Performance M-19008-BTD2 Tube Doors (2021-2022 Ford Bronco 2-Door) include tube doors, latches, and hinges, plus a handle-style addition in the middle of the door, but no steel skins. $1,599
Comparison
I'm not sure about the cost difference between steel plates and tubes, nor the amount of material contained in each, but they all appear to be relatively comparable in form and function, if not exact size and weight.
Verdict
The JcrOffroad Bronco tube doors are actually cheaper than the JcrOffroad JK Half Doors (front only), despite being a little wider. So there is no apparent "Bronco Tax" here, and the Bronco doors are arguably a better bargain for similar functionality and a lower price.
One could argue, however, that there is a "Ford Performance Tax", given the much higher price of the Ford Performance tube doors than the JcrOffroad tube doors ($550 - $700 higher price).
Summary
The results of my analysis across several different product choices at JcrOffroad is quite interesting. Despite generic allegations of a "Bronco Tax" being charged across multiple aftermarket products and vendors, my analysis seems to confirm to me that JcrOffroad is not charging a "Bronco Tax" in comparison to the pricing of some of its comparable Jeep products, which have been on the market for several years, even though they have been quick to market on some of these products, and have faced little competition to date post-Bronco release.
Follow-Up
What do you think about this analysis? Do you agree or disagree, and why?
I would love to see other members perform this type of analysis on additional aftermarket products that they feel include a "Bronco Tax" premium.
Feel free to step up, grab the mike, and determine if this so-called "Bronco Tax" is real. If it's real, tell us who is charging it, and how much is the premium?
Jeep
Comparison
Verdict
Jeep
Comparison
Verdict
Jeep
Comparison
Verdict
Jeep
Ford Performance
Comparison
Verdict
Summary
Follow-Up
