618TRVLWILD
Ashley
Southern Illinois
Big Bend Sasquatch 2D
Stig got photos all the wheel sizes and offset numbers for y'all that are on the rims! Hope this helps with tire upgrade plans! Enjoy.
Table added by @North7
Ford Bronco ⚙ 2021+ Bronco 6th Gen - OEM Factory Rims / Wheels Specs (Sizes, Offsets, Bolt Pattern, Center Bore) ⚙️ 2021 Ford Bronco Wheels Sizes Offsets Specs chart
Bolt Pattern:
6 x 5.5 (6 x 139.7)
Center Bore:
93.1
Ford Bronco ⚙ 2021+ Bronco 6th Gen - OEM Factory Rims / Wheels Specs (Sizes, Offsets, Bolt Pattern, Center Bore) ⚙️ 2021 Bronco - Factory Rims : Wheels Specs 2
Ford Bronco ⚙ 2021+ Bronco 6th Gen - OEM Factory Rims / Wheels Specs (Sizes, Offsets, Bolt Pattern, Center Bore) ⚙️ 2021 Bronco - Factory Rims : Wheels Specs 1
Ford Bronco ⚙ 2021+ Bronco 6th Gen - OEM Factory Rims / Wheels Specs (Sizes, Offsets, Bolt Pattern, Center Bore) ⚙️ 2021 Bronco - Factory Rims : Wheels Specs 3
Ford Bronco ⚙ 2021+ Bronco 6th Gen - OEM Factory Rims / Wheels Specs (Sizes, Offsets, Bolt Pattern, Center Bore) ⚙️ 2021 Bronco - Factory Rims : Wheels Specs 4
Ford Bronco ⚙ 2021+ Bronco 6th Gen - OEM Factory Rims / Wheels Specs (Sizes, Offsets, Bolt Pattern, Center Bore) ⚙️ 2021 Bronco - Factory Rims : Wheels Specs 5
Ford Bronco ⚙ 2021+ Bronco 6th Gen - OEM Factory Rims / Wheels Specs (Sizes, Offsets, Bolt Pattern, Center Bore) ⚙️ 2021 Bronco - Factory Rims : Wheels Specs 6
Ford Bronco ⚙ 2021+ Bronco 6th Gen - OEM Factory Rims / Wheels Specs (Sizes, Offsets, Bolt Pattern, Center Bore) ⚙️ 2021 Bronco - Factory Rims : Wheels Specs 7
Ford Bronco ⚙ 2021+ Bronco 6th Gen - OEM Factory Rims / Wheels Specs (Sizes, Offsets, Bolt Pattern, Center Bore) ⚙️ 2021 Bronco - Factory Rims : Wheels Specs 8
Ford Bronco ⚙ 2021+ Bronco 6th Gen - OEM Factory Rims / Wheels Specs (Sizes, Offsets, Bolt Pattern, Center Bore) ⚙️ 2021 Bronco - Factory Rims : Wheels Specs 9
Ford Bronco ⚙ 2021+ Bronco 6th Gen - OEM Factory Rims / Wheels Specs (Sizes, Offsets, Bolt Pattern, Center Bore) ⚙️ 2021 Bronco - Factory Rims : Wheels Specs 10
Ford Bronco ⚙ 2021+ Bronco 6th Gen - OEM Factory Rims / Wheels Specs (Sizes, Offsets, Bolt Pattern, Center Bore) ⚙️ 2021 Bronco - Factory Rims : Wheels Specs 11
Ford Bronco ⚙ 2021+ Bronco 6th Gen - OEM Factory Rims / Wheels Specs (Sizes, Offsets, Bolt Pattern, Center Bore) ⚙️ 2021 Bronco - Factory Rims : Wheels Specs 12
Ford Bronco ⚙ 2021+ Bronco 6th Gen - OEM Factory Rims / Wheels Specs (Sizes, Offsets, Bolt Pattern, Center Bore) ⚙️ 2021 Bronco - Factory Rims : Wheels Specs 13
Ford Bronco ⚙ 2021+ Bronco 6th Gen - OEM Factory Rims / Wheels Specs (Sizes, Offsets, Bolt Pattern, Center Bore) ⚙️ 2021 Bronco - Factory Rims : Wheels Specs 14
Ford Bronco ⚙ 2021+ Bronco 6th Gen - OEM Factory Rims / Wheels Specs (Sizes, Offsets, Bolt Pattern, Center Bore) ⚙️ 2021 Bronco - Factory Rims : Wheels Specs 15
618TRVLWILD
618TRVLWILD
Ashley
Southern Illinois
Other than buying a Wildtrack or FE, how do I get black beauty/vanity rings instead of "warm alloy"? Costs?
I'm going to powder coat mine. So say that's the best option!
Blksn955.o
Greg
Wentzville, MO
So the 17x8 in is a +55 while the squatch is 17x8.5 +30. Just making sure as the 17in steel wheels look to read 17x7.5 -55.
Blksn955.o
Greg
Wentzville, MO
Oh...forgot. THANK YOU STIG!
j_marinelli
Spring Branch, TX.
Ok I feel like we need to start asking for photos of green V8 broncos. Apparently Stig delivers and makes things a reality LOL ?
