Ill tempered sea bass?Lazer beams.... LMAO... you know what comes next @ilbastarge ... <-- Looking at you...... Fill in the blank
Thanks for the link OP!Please delete this if someone found this. Typed in the address found on the 4WheelParts Bronco walk around.
https://www.4wheelparts.com/a/ford-bronco-aftermarket-hq
Is it shark week?!?!?!Why settle?
Duplicate, the discussion thread is here.Please delete this if someone found this. Typed in the address found on the 4WheelParts Bronco walk around.
One of the guys in Babes said he asked the Ford rep about it..Ford rep said they are raising it!!Ford addressed everything with them except the most important piece...brush guards blocking BRONCO lettering...
if it's only missing 1 hero switch it was squatched then. BD would be missing 2, disco and front lockerI notice he said 3-3.5 inches of lift. I believe this is over a stock Bronc, no Squatch. To get 37's . This would make sense to me as to 32/33 are "stock", no Squatch. But if you look at the dash it has what appears to be all hero switches except one, the sta-bar. which makes sense because it is a BD
I guess my point is I believe the 3/3.5 over "stock" and don't want some to think it is 3/3.5 over Squatch, even though this is a Squatched Bronc it may have only gained 1.5/2 inches over Squatched Bronc.
I could be wrong just how I see it.
Thought it was getting lowered? I’m fine with either or..One of the guys in Babes said he asked the Ford rep about it..Ford rep said they are raising it!!
When you need a real laser beam.Lazer beams.... LMAO... you know what comes next @ilbastarge ... <-- Looking at you...... Fill in the blank
I thought @j_marinelli said it was Shark Week. I don't have steady cable so don't know.
They have date plugs. They get changed out..... No laser etching!Legit question: do they have stamps or something too change the date codes or is that like laser beams or something? Do you make batches of the same size at a time or how does that work?
