clarkT
PA & KY
2001 Mustang Bullitt
Hey team. Just got this set up. Really cool! Thank you for your hard work on this!
I am searching the internet for setting up a SIRI Shortcut bronco sport and ranger forums have had success. But it didn’t seem popular and seems to be the same person pushing it on multiple forums which made me wonder about security.
has anyone here set up a siri shortcut? It would be amazing to be able to say “hey Siri, start my bronco” to my Apple Watch or phone - all hands free!
Starting and unlocking is a repetitive series of button pressing, that’s exactly what Siri Shortcuts is for. So it should be possible to train her to execute the series “open app, click start” via a voice command.
if someone has done this, please post!
Coronabronco
Julio
Miami
Bronco Badlands
Anyone know if we can change the color of the bronco?? Mine is a race red but shows as black. Either way love the widget!! Huge thanks!!
Shacky4
Sault Sainte Marie, Michigan
Big Bend Bronco
Maybe you already know this, but you can do that with Echo/Alexa. You enable the Ford Pass skill and set a PIN. Then you can say things like: "Alexa, use Ford Pass to start the car." She'll say, "Ok, what's your pin?" You recite your 4 digit pin and your done. It's not perfect, but it's not bad.
Nick8282
Nick
Memphis
2021 Ford Explorer Sport, 2022 Ford Bronco
Anyone else getting this error message
Ford Bronco 📱 Scriptable FordPass Widget (iOS, iPad, MacOS) 849BA796-8717-4D5D-ADDC-FEA05BA77EE8
Michael Grasso
Indianapolis
2025 Ford Bronco
Once all of this is done, how do we add it to the widget section of iPhone, when i open up the customizable it is not available as a widget
RynoRanger
Chuck
Gilbert, AZ
azbluey.com
2.7L Badlands NS 4dr
you need to add a "Scriptable" widget, select size, then once the widget's on your iphone page click it.. select the FordPass script, and you should be good.
GrumpyVet
Joel
Yup you've described my setup. I was using the Scriptable widget which is cool but being able to run everything through Siri has been great. https://www.bronco6g.com/forum/thre...ts-for-fordpass-app-controls-functions.63992/
Tortuga353
Laguna Beach, FL
Mine has been giving an error for a similar time frame. Deleted reinstalled multiple times but have not been able to make it work again.
2023-03-10 07:17:53: Script Version: 2022.10.15.1
2023-03-10 07:17:53: Update Available: false
2023-03-10 07:17:53: Latest Version: 2022.10.15.1
2023-03-10 07:17:55: (Required Prefs Menu) Done was pressed
2023-03-10 07:17:55: (prepWidget) Prefs Menu Prompt Result: true
2023-03-10 07:17:55: No Token found... Forcing Token Fetch...
2023-03-10 07:17:55: Fetching Token...
2023-03-10 07:17:55: prepWidget() Error: Error: The data couldn’t be read because it isn’t in the correct format.
