I ordered the Rapid Red base. Before it shows up I hope to get a set of Ranger Raptor take off wheels & tires. I like the factory look and 32.5" will be enough for me.
Could the gasket be on the removed part?
Hey hey! Blind squirrel getting a nut!
Zoom in and the shine will be more apparent.This mod top does not look shiny. Is it possible it is a darker MIC with the window removed?
You can see the window being unlatched at about 3:30.I can see it now. You're inside the back and releasing the latches 1 by 1. You get to the final latch and.... OH SHIIIITTTTT!!! (ಥ ͜ʖಥ)
Actually, just the opposite. As seen from the video in below post, the plastic trim is more matte-finish (not glossy), matching-up better with MIC. But I don't look at it that way. Both work equally well.Just wanted to chime in that the door trim plastics match up very well with the MOD top, that looks excellent.
Obviously that means it looks a little strange with MIC, as they aren't changing this door trim by roof option.
I see the gate swings wider than the Jeep (which stops just past 90-degrees). Not something I need, and I'm glad Ford added a detent at 90-degree for most of the times you don't need that full swing (and possibly tap a nearby car).You can see the window being unlatched at about 3:30.
Esteban... Not in his garage and upset it seems.You can see the window being unlatched at about 3:30.
The pullout tailgate prevents on board door storage for someone that would do that.I see the gate swings wider than the Jeep (which stops just past 90-degrees). Not something I need, and I'm glad Ford added a detent at 90-degree for most of the times you don't need that full swing (and possibly tap a nearby car).
And that pull-out tailgate oughta just be standard across the board.
That was still in the prototyping phase. Not all Mod tops at that time even had removable windows. That’s where a huge amount of confusion came from.This opening does not appear to be the standard mod top opening which is why originally I thought this was a mic top. It is missing the catch and locking mechanisms.
Interesting, I wasn’t aware the the “porthole” top panel on the 2-door was only available on the mod top. I thought that was on both and the removable glass was the only differenceIn before someone argues this still isn’t enough proof they’re removable.
What does awesome mean?This looks awesome! If you could also remove the glass over the tailgate easily, I may be willing to pay the extra money for the modular top. Still like the MIC better though from a durability standpoint.
Now a MIC or textured top with ALL of the glass removable (maybe no gunner hatch) would definitely have my attention.
Awesome: Extremely impressive or daunting; inspiring great admiration, apprehension, or fear.What does awesome mean?
Wicked pisserWhat does awesome mean?
