Did you reach out to the dealer to grab the info?I got a rail car number!
I looked through the spreadsheet and there are two, but each is for a 4DR.I’ve seen exactly zero wildtrak built emails
I got one yesterday (1/4), but mine is a 4-door.I’ve seen exactly zero wildtrak built emails
mine just doesn't loadIs anybody else having problems with checking status using the link from the “Built” email? Started getting this yesterday.
Congrats! Our vehicles are identical twins! No "built" email for me yet, though.I got one yesterday (1/4), but mine is a 4-door.
That's an intermittent issue, don't read anything into it! It'll come back around shortly!Is anybody else having problems with checking status using the link from the “Built” email? Started getting this yesterday.
2 issues with the tracker I’ve seen. When the order/vin are flagged as incorrect (noted in red text) it’s either you’re not using the 4 digit order # which is necessary or your vin is wrong.mine just doesn't load
Your modules are populated so likely in a “in production” stage stillThank you, I’ll keep an eye on it. The value are populated from hitting the “Track You Order” link, so I’m pretty sure they are correct. I’ll check again later. Honestly, I may have the record for number of times hitting the tracker this way!!
next step i'm waiting on is shipping which I'm hopeful i'll get the tracker updated tonight and email tomorrow...but aren't we all?2 issues with the tracker I’ve seen. When the order/vin are flagged as incorrect (noted in red text) it’s either you’re not using the 4 digit order # which is necessary or your vin is wrong.
when it just refreshes the page, the 2x that happened to me, it came back to life 24-48 hours later and the EDD was updated when I looked closely.
Hope that helps
