For those doing a self installation of the 2" puck style lift kits I found it to be a much easier remounting of each spring after the spacer is installed by mounting them on opposite sides they came off of due to the bolt pattern change which causes top end spring angle to be inconsistent with frame mounting brackets, which in turn makes it very difficult to start nuts onto the outer two bolts.
