GreenMtnBronco
West Nyack NY & Central VT
'21 BadSquatch; 13 Wrangler JK; 04 Lifted Mini
Thank you, I appreciate it for sure. I'll say I have more than that in total mods.
The Ford Performance Hoss 3.0 steering rack still has issues, maybe less of a chance of breaking as the original steering rack. But, if you really don't want to ever worry out on trails then I would def go with the 74Weld. But I haven't had any issues with steering.
this is my build, also haven't had issues with the steering, but you don't have issues, until you do...
https://www.bronco6g.com/forum/threads/green-mountain-bronco-build-on-37s-3-lift-more.40386/
TailChaser
Kentucky
2023 Bronco OB Sasquatch
Sweet rig. I’d recommend new tires for the market you’re after that wants to do nothing and doesn’t care about the money, just judging from pics. They’ll be covered up in business stuff and have no time, but make enough to not blink at the money. I’d consider it if I hadn’t already bought one. Sweet rig.
Felix808
SRV CA
:confused:
badbronc4x4
badbronc4x4
Cory
Scottsdale, AZ
2022 Ford Bronco Badlands Sasquatch
Here is some new pics I recently had taken.
Ford Bronco 2022 Ford Bronco Badlands - @Bad_bronc_4x4 Fully Built Long Travel Baja Kit, ADV Fiberglass Fenders and Hood and More!! F2C05665 copy
Ford Bronco 2022 Ford Bronco Badlands - @Bad_bronc_4x4 Fully Built Long Travel Baja Kit, ADV Fiberglass Fenders and Hood and More!! F2C05690 copy
Ford Bronco 2022 Ford Bronco Badlands - @Bad_bronc_4x4 Fully Built Long Travel Baja Kit, ADV Fiberglass Fenders and Hood and More!! F2C05691 copy
Ford Bronco 2022 Ford Bronco Badlands - @Bad_bronc_4x4 Fully Built Long Travel Baja Kit, ADV Fiberglass Fenders and Hood and More!! F2C05696 copy
Ford Bronco 2022 Ford Bronco Badlands - @Bad_bronc_4x4 Fully Built Long Travel Baja Kit, ADV Fiberglass Fenders and Hood and More!! F2C05706 copy
Ford Bronco 2022 Ford Bronco Badlands - @Bad_bronc_4x4 Fully Built Long Travel Baja Kit, ADV Fiberglass Fenders and Hood and More!! F2C05707 copy
Ford Bronco 2022 Ford Bronco Badlands - @Bad_bronc_4x4 Fully Built Long Travel Baja Kit, ADV Fiberglass Fenders and Hood and More!! F2C05711 copy
Ford Bronco 2022 Ford Bronco Badlands - @Bad_bronc_4x4 Fully Built Long Travel Baja Kit, ADV Fiberglass Fenders and Hood and More!! F2C05716 copy
Ford Bronco 2022 Ford Bronco Badlands - @Bad_bronc_4x4 Fully Built Long Travel Baja Kit, ADV Fiberglass Fenders and Hood and More!! F2C05719 copy
Ford Bronco 2022 Ford Bronco Badlands - @Bad_bronc_4x4 Fully Built Long Travel Baja Kit, ADV Fiberglass Fenders and Hood and More!! F2C05721 copy
Ford Bronco 2022 Ford Bronco Badlands - @Bad_bronc_4x4 Fully Built Long Travel Baja Kit, ADV Fiberglass Fenders and Hood and More!! F2C05724 copy
Ford Bronco 2022 Ford Bronco Badlands - @Bad_bronc_4x4 Fully Built Long Travel Baja Kit, ADV Fiberglass Fenders and Hood and More!! F2C05726 copy
Ford Bronco 2022 Ford Bronco Badlands - @Bad_bronc_4x4 Fully Built Long Travel Baja Kit, ADV Fiberglass Fenders and Hood and More!! F2C05727 copy
Ford Bronco 2022 Ford Bronco Badlands - @Bad_bronc_4x4 Fully Built Long Travel Baja Kit, ADV Fiberglass Fenders and Hood and More!! F2C05739 copy
Ford Bronco 2022 Ford Bronco Badlands - @Bad_bronc_4x4 Fully Built Long Travel Baja Kit, ADV Fiberglass Fenders and Hood and More!! F2C05742 copy
Ford Bronco 2022 Ford Bronco Badlands - @Bad_bronc_4x4 Fully Built Long Travel Baja Kit, ADV Fiberglass Fenders and Hood and More!! F2C05694 copy
Ford Bronco 2022 Ford Bronco Badlands - @Bad_bronc_4x4 Fully Built Long Travel Baja Kit, ADV Fiberglass Fenders and Hood and More!! F2C05714 copy
Ford Bronco 2022 Ford Bronco Badlands - @Bad_bronc_4x4 Fully Built Long Travel Baja Kit, ADV Fiberglass Fenders and Hood and More!! F2C05725 copy
Ford Bronco 2022 Ford Bronco Badlands - @Bad_bronc_4x4 Fully Built Long Travel Baja Kit, ADV Fiberglass Fenders and Hood and More!! F2C05749-Enhanced-NR copy
Ford Bronco 2022 Ford Bronco Badlands - @Bad_bronc_4x4 Fully Built Long Travel Baja Kit, ADV Fiberglass Fenders and Hood and More!! F2C05684 copy
badbronc4x4
badbronc4x4
Cory
Scottsdale, AZ
What is this? You add a heated steering wheel?
No, I have the heated steering wheel but doesn't get hot or warm enough so there is a code in for scan to make it warmer.
