Cactus Jack
OH
2022 Bronco Raptor
Using a word processor, the Bronco Raptor's Width and Height were calculated.
The known Outer Banks dimensions were used as a reference.
The calculations show that the Bronco Raptor will be around:
86" In Width (Fender Flare to Fender Flare)
78.5" Tall
**Please note that each inch on the drawing represents around 22" IRL
The height calculation gave 22.33" for every inch while the width calculation gave 21.71" for every inch.
Considering the F-150 Raptor with 37" Tires is 86.6" Wide and 79.8" Tall, it appears Bronco Raptor will follow a very similar profile.
Ford Bronco 2022 Bronco Raptor Height & Width Calculated Using Images Calculating 2022 Bronco Raptor Height
Ford Bronco 2022 Bronco Raptor Height & Width Calculated Using Images Width
Ford Bronco 2022 Bronco Raptor Height & Width Calculated Using Images Screen Shot 2021-12-02 at 8.58.44 PM
Ford Bronco 2022 Bronco Raptor Height & Width Calculated Using Images Screen Shot 2021-12-02 at 8.57.55 PM
MayhemMike
Mercury
I would buy the Raptor truck. Once you sit and drive one with the 37 package one has no idea how fantastic they are.
Silver-Bolt
Bill
Eureka, MT
Measure the width of the mirrors on a standard Bronco and you will be very close the the width of the Raptor Bronco. The outside to outside dimension on the mirrors appears to be very close to the width of the outside to outside flare dimension on the Braptor.
chadasm
Chad
New Mexico
2013 Raptor, 2017 Focus ST, 2019 F450
Good observation. At least you're less likely to hit your mirrors on anything. If you're about to hit your mirrors, you've already taken out the flares/ran over it.
bytheway
Brice
Louisville, KY
We know it's over 80" wide because of the lights in the grille. So the estimates seem reasonable.
Blue's B6G
Jeremy
Los Angeles
2021 Bronco OB 2-Door V6 Sasquatch AMB High Pack
Thought I’d love the Bronco Raptor, but it’s a little too over the top for my taste. May be just me, but it looks goofy with the bottom-half twice as wide as the top-half of the vehicle.
Sasquatch is perfect IMO.
Ford Bronco 2022 Bronco Raptor Height & Width Calculated Using Images 1638552867479
PatientlyWaiting
Brent
Marietta GA
MY22 Wildtrak
I would like to see the comparison to a sasquatch ride. I was just going to pull the specs from the Ford site for a Wildtrak. Problem is the website lists the same height for the Wildtrak as it does for the Outerbanks.
KompressorV12
Portland, Oregon
19' Jeep Grand Cherokee High Altitude
Yeah can we get SAS comparisons please?
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
HorizonHunter
Joseph
Chapel Hill, NC
Grand Cherokee Trailhawk
Perfect summary. The F150 looks like a wholly different truck. The Bronco just looks like it has ridiculously big flares on it.
jaruss01
NJ
Bronco Raptor looks to have identical mirrors, and the regular bronco width with mirror is 86.2". So you seem pretty spot on, since the mirrors look to be flush with the raptor flares.
The crazy part (well, just goes to show how foolish some of the proportions are) but the regular bronco sasquatch is 79.1" width, and the flares are exactly flush to the tires (if you calculate the track width). The sas flares are 5" wide. For the Raptor, the flares would calculate to 8.5"+ wide, which is pretty ridiculous. Non sas flares = 3.5"; sas flares = 5", Raptor flares = 8.5+"
The space inbetween the front two wheels is a foot wider than the top of the hardtop.
Silver-Bolt
Bill
Eureka, MT
But we have not seen the corner lights on each fender which are required. It will not be as wide as the F150 Raptor.
jay-rod427
Jerod
KS
Carbonized gray 2 dr BadLands Sans-Squatch ordered
Prkelly
Pat
Washougal
is it me or do the Mirrors look to be the same distance apart
Prkelly
Pat
Washougal
I should of read this before I posted :cool:
