Metal-tech 4x4 released our 2D FRAME mounted sliders about a month ago. You can learn more about them seeing how they mount under the truck. The magic is in the mounts supporting the Boxed main rail sliders that feature Metal-tech 4x4, trademarked two stage rub rail made from 1.75" x .120" wall DOM tubing. The kickout in the slider helps push your trucks body away from obstacles to help save your quarter panel. The outer rub rail is also outside the radis of the doors if you look down the side the truck. This saves you from trees, rocks from hitting your doors. (Ok parking lot car doors too)
We work hard to keep these in STOCK so little to no waiting. If we do run out, usulay a run is in powder coating.
