Thanks HeritageRider. I know better than thatExcept that you can't have the 7MT with squatch and 35's....
Where have you been? There was a 45 page thread about it!Since when? Sasquatch comes with 35's, always, and can be put on any Bronco regardless of transmission. Only thing you can't get is 7MT with the 2.7L V6.
You cannot get Squatch with manual.Since when? Sasquatch comes with 35's, always, and can be put on any Bronco regardless of transmission. Only thing you can't get is 7MT with the 2.7L V6.
My apologies for the misinformation. I stand corrected.
The Badlands comes stock with 4.7:1 AND 33” tires.Are you doing 7MT or 10AT?
With 7MT you get the crawl ratio of the Badlands and the lockers, etc.
For the 10AT, Ford seems to be carefully adjusting the gearing to tire size to optimize fuel efficiency (so you’d have a 4.7 when a 4.46 would be the right choice)
Nice explanation!Badlands non-Sas is 4.27 gearing iirc, running 33s on those would be fine.
Sas base(or any trim) is 4.70 with the 35s.
Speaking with linearity they skip the 4.46 gearing that’s available to go up two notches to 4.70. That’s not only overcoming the added diameter and weight, that’s adding some performance to the whole package.
Moving up tire sizes will decrease the RPM the engine turns for any given speed.(and visa versa)
Moving to Steeper gears will Increase the RPM the engine runs at any given speed (and Visa Versa)
So going to the steepest gear set, and then Decreasing tire sizes means your effectively increasing your gearing. I don’t have a calculator handy but your effective gear ratio is close to 4.9X at that point.
Gearing has a sweet spot where not enough means bad fuel economy, and too much also means bad fuel economy.
Only with the manual. With automatic it's 4.46:1. Sasquatch gets you 4.70:1.The Badlands comes stock with 4.7:1 AND 33” tires.
Ford seems to think it’ll run fine.
JK
The original question was about tire size and gears. Even with the MT Ford thinks a smaller engine and higher gears will spin the 33s just fine. ?‍Only with the manual. With automatic it's 4.46:1. Sasquatch gets you 4.70:1.
I think you misread my reply. The 2.7 with an auto doesn't have 4.7:1, it has 4.46:1.The original question was about tire size and gears. Even with the MT Ford thinks a smaller engine and higher gears will spin the 33s just fine. ?‍The 2.7 in auto with 4.7:1 should be fine. The Bronco isn’t a Prius and never will be ...
JK
The Sasquatch package (which requires AT) has 4.7:1.I think you misread my reply. The 2.7 with an auto doesn't have 4.7:1, it has 4.46:1.
Yes, which is why I said:The Sasquatch (which requires AT) has 4.7:1.
JK
Hi AH64DB2 (you badass Apache guy - Hooah), if you plan to mount 33" on the Outer Banks you'd probably do best to go up to the optional 4.27:1 rear axle ratio instead of standard 3:73:1 to offset the engine RPM drop with the larger tires. You want torque curve to be in the right place during low-speed ops. ps. thanks for your service. ??What about putting 33” on the Outer Banks?
I used to be cool... now not so much. Thanks for the advice.Hi AH64DB2 (you badass Apache guy - Hooah), ??
