4-banger spark plug swap: Best $50 noise reduction ever!
BoverW
J
Socal
Hit the 45k mark. This 2.3L has always been a grumpy little engine at idle—a little rough, a little loud. I thought it was normal for the 2.3L engine. Now it is buttery smooth.
So, the old plugs look fine at the tip—clean and dry. But the ceramic has some brown stains on it. Is that just the usual corona stain, or am I looking at something scarier, like arc leakage? All 4 look like this.
This is the original plug, straight from the factory. Getting them out feels more than spec ( I think it is 131 inchpounds ?)
Ford Bronco 4-banger spark plug swap: Best $50 noise reduction ever! IMG_9808
Not unusual for the color or the torque - keep in mind they’ve been subject to more than a few dozen thermal cycles over 45k miles
mine were similar - and had similar results when I changed them
CalvinT
Calvin
Phoenix, AZ
Brown is good. In olden days that's how we could tell we had the carburetor jetted properly.
Dirtrider
Bruce
St. Louis
Honda Ridgeline, Super-C Motorhome
Mine seems to idle pretty smoothly. ('22 with ~33k miles). Changing the plugs smoothed it out and reduced the noise?
BoverW
BoverW
J
Socal
. Here is what genAI's explanation is. I think it makes sense. But still, if it is smooth for you, then no need to waste money.
Changing spark plugs improves idle smoothness because it restores combustion consistency.
When an engine idles, it is actually operating under difficult conditions for ignition: air and fuel are moving slowly, and the mixture is often "lazy" (low turbulence). This makes it harder to light the fuel evenly every single time.
Here is the breakdown of why new plugs solve this:
1. The "Sharp Edge" Effect (Voltage Demand)
  • Old Plugs: As spark plugs wear, the center electrode becomes rounded and the gap (the distance the spark must jump) widens. Electricity struggles to jump from a rounded surface; it prefers a sharp point. A rounded, wide gap requires much higher voltage to fire.
  • New Plugs: They have sharp, clean edges and the precise factory gap. This allows the spark to jump easily and consistently with less stress on the ignition coils, ensuring a spark occurs exactly when the computer commands it.
2. Flame Kernel Strength
  • Old Plugs: A weak or struggling spark creates a "weak flame kernel." This means the fire inside the cylinder starts slowly or unevenly. At idle, this results in a weak power stroke for that specific cylinder.
  • New Plugs: A healthy spark creates a large, hot flame kernel that ignites the fuel instantly and completely. This ensures that every cylinder pushes the piston down with the exact same amount of force.
3. Reducing Misfires
"Rough idle" is often a series of micro-misfires. If a spark plug fails to ignite the fuel just 1% or 2% of the time (which is common with old plugs), you feel a "stumble" or vibration in the steering wheel and seat.
  • Why it's noticeable at idle: At high speeds (e.g., 3,000 RPM), the engine's momentum (flywheel inertia) smooths out these tiny misses, so you don't feel them. At low speeds (e.g., 700 RPM), the engine has less momentum, so every single missed or weak combustion event causes a noticeable shake.
CalvinT
Calvin
Phoenix, AZ
AI is correct for an engine with a Kettering system (points and condenser). Modern electronic ignition systems have a hotter spark. Also a faster rise time so the spark isn't bled off by a dirty spark plug or bad wires.
The problems with idle that AI metioned apply to engines with carburetors or port injection. Both Bronco engines have direct injection, mixture problem solved.
Bring up those two points with your AI agent and see what the response is. I'm curious.
BoverW
BoverW
J
Socal
The problems with idle that AI mentioned apply to engines with carburetors or port injection. Both Bronco engines have direct injection, mixture problem solved.
Thanks for sharing your knowledge.
I would like to do an exact follow-up, but d**n, my subscription just expired. I started the question with a pro account, and I cannot continue on that exact thread :confused:
Anyway, I restarted with the same question and sent you points. Here is the response.
You are absolutely right that modern high-energy ignition systems (Coil-on-Plug) and Direct Injection (DI) have solved many of the "gross" errors of older engines. You don't get the wet-fouling of a carburetor or the weak yellow spark of a distributor.
However, your 6G Bronco's Direct Injection engine actually introduces new, specific physics challenges at idle that make spark plug geometry arguably more critical than in older engines, not less.
Here is why a new plug smoothes out a DI idle, even with a high-voltage ignition system.
1. The "Targeting" Problem (GDI Specific)
In your old port-injected engine, fuel was sprayed upstream, tumbling over valves and mixing with air long before it hit the spark plug. It was a well-mixed "fog."
  • The DI Challenge: Your Bronco sprays liquid fuel directly into the cylinder at 2,000+ PSI. At idle, the computer often uses "split injection" (multiple tiny squirts per stroke) to keep the flame stable.
  • The Spark Plug's Job: The spark plug is no longer igniting a pre-mixed fog; it is often igniting a specific "swirl" of fuel vapor that is being directed at the plug gap by the piston shape.
  • The Wear Factor: As the ground electrode wears down, the gap location moves slightly (upward) and the spark arc changes orientation. In a DI engine, if that spark moves even 1mm out of the ideal "fuel plume," you get a partial burn. You feel this as a rough idle.
2. High Pressure = High Resistance
You mentioned modern systems have a "hotter spark," which is true. They can produce 30,000+ volts. But they only produce exactly as much voltage as is needed to jump the gap.
  • Physics of Pressure: It is much harder for a spark to jump a gap in high pressure (cylinder compression) than in open air. Direct Injection engines typically run higher compression ratios (often 10:1 or higher) than older engines.
  • The "Quench" Effect: Even with a powerful coil, a worn plug with a rounded center electrode requires significantly higher voltage to initiate the jump. This higher resistance can cause the spark to form "late" (in microseconds) or essentially "blow out" if cylinder pressures fluctuate slightly at idle. A sharp new plug concentrates the electric field, allowing the spark to jump at a consistent, lower voltage, ensuring the timing is perfectly in sync with the fuel spray.
3. The "Carbon Valve" Effect (Bronco Specific)
You correctly noted GDI solves mixture delivery, but it creates an airflow problem.
  • No Fuel Wash: Because fuel is sprayed inside the cylinder, it never washes the intake valves. Over time, carbon from PCV vapors builds up on the back of the intake valves (a known issue with EcoBoost engines).
  • Turbulence disruption: This carbon restricts and disrupts the smooth airflow (tumble) entering the cylinder at low speeds (idle).
  • The Plug as Compensation: When airflow is turbulent and unpredictable due to valve carbon, the flame kernel is easily extinguished. A fresh spark plug with a sharp, intense kernel is essentially "powering through" the bad airflow dynamics caused by the carbon buildup.
4. The EcoBoost "Gap Sensitivity"
Specifically for the Ford EcoBoost platform (2.3L or 2.7L in your Bronco), these engines are notoriously sensitive to gap growth.
  • Boost vs. Idle: While you feel the roughness at idle, the wear often happens under boost (turbo usage), which eats away electrodes faster than naturally aspirated engines.
  • The Result: Ford owners often find that even a small increase in gap (e.g., from 0.030" to 0.036") causes idle instability because the ignition coils are optimized for a specific resistance window. Once the gap opens, the coil struggles to maintain spark duration (burn time). A short burn time at idle = incomplete combustion = roughness.
Summary
Your modern ignition is powerful, but it is fighting a harder battle. It has to ignite a heterogeneous (unmixed) fuel spray in a high-pressure environment, often with disrupted airflow from valve deposits.
  • Old Tech: Masked poor mixture with a long, lazy spark.
  • New Tech (GDI): Requires surgical precision. A worn plug loses that precision, leading to cycle-to-cycle variation that you feel as a "shake."
CalvinT
Calvin
Phoenix, AZ
Thanks for getting back with the AI results.
Interesting. Many good points, not that I agree with all of them. The most glaring is the comment about the gap locating moving upward. Look at the spark plug. The spark remains centered. The spark gap is 0.27- 0.31 for the 2.3 L engine. It MAY erode depending on electrode material. We had to regap nickel based electrodes every 10, 000 miles or less. That is if we didn't just replace the plugs. The plugs in the Bronco have iridium electrodes, very little wear. The spark probably moves less than a couple of thousanths of a inch before scheduled replacement. Not enough to matter. If you want to double check, measure the gap of your old plugs and compare with new plugs.
The comment "But they only produce exactly as much voltage as is needed to jump the gap." Is misleading. All spark systems only produce as much voltages as needed to jump the gap. It's not a characteristic of the ignition system as implied. It's a characteristic of current flow across a spark gap. Once the spark is struck, voltage remains constant until you exceed the current capacity of the electrodes. That won't happen in an ignition system. The actual current is around 5 - 25ma. In short ALL ignition systems only provide enough voltage to jump the gap. They can't provide more voltage unless the gap is made wider to increase voltage required to jump it.
If you look at the center electode you notice it's a small wire. That reduces the quench effect. The sharper a radius or smaller the wire, the easier it is for a spark to form.
When cars had carburetors typical idle fuel mixture was around 12:1 to get the engine to fire. There was little turbulance at idle. (Another error the AI made) Direct injection engines don't need a mixture that rich because the injector aims fuel at the spark plug, the fuel is timed with the spark.
I think new plugs probably did help smooth out your engine. I'm amazed that spark plugs last as long as they do. But the situation isn't as dramatic as the AI implies.
Be careful when using AI. Think of it as a very bright, even nerdy engineering graduate who has zero real world experience. It can easily lead you astray if you're not careful.
I use AI quite a bit and I find I often have to challenge its results to correct errors like I pointed out. I'm constantly reminded that AI doesn't really "undestand" what it's saying. It's doing a statistical analysis of relevant articles that it finds online. It doesn't always understand context. So it's necessary to prune away assumptions that it's made.
An example... I was using it to size a solar panel to charge a battery that runs my telescope when I'm star gazing. After some back and forth it made the observation that with the right size panel I could charge my battery while I was looking at the stars. Then I pointed out that there was no sun when I was star gazing. Like I said, no real world experience.
RoLyMa27
Rodney
SloKart, TX
21 Bronco 2dr, 26 Explorer ST
Look at that...A human kicking Ai's ass. I love it.
BoverW
BoverW
J
Socal
An example... I was using it to size a solar panel to charge a battery that runs my telescope when I'm star gazing. After some back and forth it made the observation that with the right size panel I could charge my battery while I was looking at the stars. Then I pointed out that there was no sun when I was star gazing. Like I said, no real-world experience.
If you want to double-check, measure the gap of your old plugs and compare with the new plugs.---> I don’t have a new plug to compare with, but I just measured all four of my old plugs. Three came in at 0.31, and one was slightly bigger at 0.32. That tiny difference might add a bit of roughness.
I think the AI’s take is on point — It is looking for reasons for uneven combustion from worn plugs. But I don't have enough domain knowledge to judge its output. I’m with you on AI. It is an awesome tool for digging up info since it’s basically reading the whole internet, You still need good background knowledge to sort out what’s useful. That’s where I’m still learning, so I really appreciate hearing from experts like you. :)
BoverW
BoverW
J
Socal
In your experience, what could be potential causes? I trust my ass and ear, new plugs definitely improve smoothness. I am curious to know why.
CalvinT
Calvin
Phoenix, AZ
Simply put, your old plugs are dirty, the new ones are clean. The gap is close enough. Spark gaps shouldn't be that critical (see next paragraph). That's why the specification isn't exact. A combustion chamber is an undefined environment, meaning they don't have an exact mathematical model of what happens in one.
I did a little research. The 2.7L and 2.3L engines seem to use the same spark plug. But Ford specifies 0.28 - 0.31 for the 2.7L engine. That's a 10% range which is typlcal. But Ford specifies 0.30 exactly with no tolerance. This implies something critical. Or a different engineering team wrote the specification.
Setting gaps on a spark plug is a bit of an art unless you have gap setting pliers. I always went by feel using a gap gage. It's sort of like horseshoes, close is good.
Your comment makes me think something else could be going on. New plugs are masking a problem.
However... I don't know what you're comparing your Bronco to. If your previous DD was a six or a V8 the 2.3L may feel rough to you without anything being wrong.
I'm happy with my 2.3L But my previous daily driver was a Subaru.
BoverW
BoverW
J
Socal
I am just trying to share my observations. If anyone can explain why, that is a plus :)
My comparisons are mostly between different setups on my own Bronco and test drives with 2.7L engine Bronco. At the beginning, I knew 2.3 was louder than 2.7, so really, no complaint then. I drove past 45k and no engine code, so I do think it is within the reasonable range (maybe upper bound in my case)
And honestly, NVH is complicated. Everything in the vehicle plays into everything else. I’m just sharing what I’ve felt after a bunch of mods.
Here is the comparison when idle
1. Test-drive 2.7L vs mine( Stock Bilstein + soft top + Goodyear)
Smoothness wasn’t as good as 2.7L; noise was fine.
2. Stock Bilstein + soft top + KO2 E-load
I don't really tell a difference here.
3. Stock Bilstein + TOR hardtop + KO2 E-load
Rough idle, loudest cabin boom when idle. Driving is much better. This is the time I notice more about the idle condition.
The suspension and tires didn’t provide enough damping, I guess. The engine’s rough idle made it straight into the cabin. Probably matched the hardtop’s resonance because it legit felt like sitting inside a drum.
At that point, I loved auto start-stop because my eardrums would get uncomfortable at stoplights. (This is a bit of personal experience. I’m the type who feels pressure changes a lot when altitude changes. Some of my friends never feel it. )
4. FOX HOSS 3.0 + TOR hardtop + KO2 E-load
Smoothness improved, and noise dropped a lot. Here, I think the suspension actually filters out some of the vibrations.
5. 4WP coilover + TOR hardtop + Falken AT4W C-load
Slightly better smoothness/noise level. Softer tire and different dampers.
6. 4WP coilover + TOR hardtop + Falken AT4W C-load + new spark plugs
Major improvement on idle smoothness, noticeably quieter—basically on par with the 2.7.
These setups vary so much that it’s basically YMMV. And honestly, sometimes you just never get a solid reason why :)
CalvinT
Calvin
Phoenix, AZ
Doesn't help that the Bronco is inherently noisy. Trim package also makes a difference. I have the high package on my Badlands. The high packate included extra underhood and body sound deadening. Other than the wind noise from the top it's a luxury car compared to my Subaru.
Noticing stuff is a pain, but it also keeps you from ignoring something that may end up being a problem later.
